Competition Diesel racing, sleds, dynos, power tuning and max performance.
Getting a good burnout going
Old 02-04-2007, 10:55 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
How do you guys with manuals get a good burnout going? Auto is easy...slam the brakes and then the gas... manuals giving me some issues, so I turn to the diesel comp guys, since we have no gas comp forum.
Stop the truck while in first and just hold the gas down?
Suggestions appreciated.
Old 02-05-2007, 04:24 AM
VQ2Fast4U's Avatar
VQ2Fast4U
VQ2Fast4U is offline
Heel toe braking, this is a technique used for downshifting when racing. But im sure it would work for a burn out. Just use the ball of your foot to press the brake, while doing that turn your foot and use your heel to press the gas at the same time. Hope that makes sence.
Old 02-06-2007, 03:31 AM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
Zach, usually the way I do it is put it in second gear try to pull the truck to a stop with the brakes and lay down on the throttle. Sooner or later the rear tires are going to overcome wanting to stop, and let the burnout ensue!!! Alot of times my front tires start skidding, but it will hook sooner or later. In my gassers, I did the heel toe thing and just dropped it. That makes me nervious in this machine. It's got enough torque to really tear some shizzle up. Though I'm sure it would burn the tires just the same. Sooner or later, alcohol will end the debate of weather or not I should drop it. I'll let you know when it does.
Old 02-06-2007, 04:55 AM
79superduty's Avatar
79superduty
79superduty is offline
Talking
with 700hp i just smash the gasss.
Old 02-06-2007, 09:41 AM
wizzard351's Avatar
wizzard351
wizzard351 is offline
hold the gas down drop the clutch and stab the brake never lettin off the throtle.i have ben noted to use a vice grip with the jaws wraped in blacktape to pinch off the rear rubber brake line to get a nice rosty toasty goin for pic's dont ride around with it pinched off tho
Old 02-06-2007, 10:55 AM
RangerPilot
Thanks for all the help guys. I used RubberDuck's way, as that was kinda what I was thinking beforehand, coast to a slow roll, hit the brakes, then the gas, and increase both. Tires unlock, truck comes to a quick stop, and voila...lots of smoke for my entertainment!
Thanks guys, I'm sure all methods will come in handy!
Old 02-25-2007, 02:18 AM
jimbo beam's Avatar
jimbo beam
jimbo beam is offline
if you want lots of smoke, and not just from the tires. simply press in the clutch, put gas to the floor and release clutch. somethings bound to burn and/or smoke.
i road around with a buddy that use to do that to a tempo, it didnt fair to long.
Old 02-25-2007, 12:05 PM
RangerPilot
I'd like some longetivity to go with my fun...
I've got it pretty well down now...thanks for the help guys.
Old 03-02-2007, 10:06 AM
FivePointo's Avatar
FivePointo
FivePointo is offline
Roll control .. line lock .. call it what you want, works like a charm
Old 03-03-2007, 11:44 PM
furball69's Avatar
furball69
furball69 is offline
Line lock is the proper way to do it.
Old 03-04-2007, 02:37 AM
phil6608's Avatar
phil6608
phil6608 is offline
Yes a good line lock kit is the best way and a lot better for the truck.
Old 03-04-2007, 11:17 AM
RangerPilot
Any suggestions on best brands for line lock? I saw a reference to Hurst and they seem to put out good products.
Thoroughbred Diesel
General Diesel Discussion
10-20-2016 11:23 AM
Docindahouze
2017+ Super Duty
15
09-19-2016 07:23 AM
Kyre Searcher
25
07-29-2016 05:30 PM
FordGuy0131
Competition
02-13-2009 10:12 PM
tjthegreat
40
03-09-2008 11:01 PM
Quick Reply: Getting a good burnout going
