Clear Coat Refresher?
Old Feb 11, 2007 | 02:45 PM
Dirty K's Avatar
Dirty K
Sorry, i will admit that i didn't search before posting this question, but only because the search feature wasn't available at the time of this post.
Anyways, I was wondering if it was possible to refresh an old clear coat finish(1998 model) without respraying. My first idea was to cut and buff the coat. Any ideas. I have all the tools. I use to be an automotive painter apprentice. It was a fun job, just alot of work.
Old Feb 11, 2007 | 03:54 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Yep, you can definitely cut it if you want by wetsanding if needed. The first question though is just how bad is it ? Are you talking about oxidation or car wash scratches and the like ? If so, I would just use a good 1500 grit compound to start with on a medium cut compound pad, then move into a swirl remover after that on a polishing pad, then a nice coat of wax applied with an orbital or by hand depending. Just remember, when it comes to buffing, it's not about setting a world record in speed, take your time and allow the products to do the work along with your buffer, running it full tilt will get you nothing more than a burned up paint job. Depending on the size of the vehicle and just how bad it is, plan on spending a couple hours out in the garage, but it'll be worth it. I know this is a Ford site, but I'm probably going to put a few pictures in my Gallery of some of the cars I've put together in the past few years, and even some of the current projects, just for kicks.
Old Feb 11, 2007 | 06:29 PM
Dirty K's Avatar
Dirty K
Yea its mainly just oxidized, covered with sap, and just a pretty nasty color over the oxford white. I might do it piece by piece just so i can focus on not burning it. Speaking of pictures i might put up an Auburn custom paint hood I made for a good friend for his graduation present.
Old Feb 12, 2007 | 05:07 PM
Indy_Gearhead71
The tree sap might give you some fits, it can be a real PITA to get off and if it has been on there a while, there's a good chance it corroded the clear a bit. Not to say those marks won't come out, but there might be a little bit of residual marking left over. The lucky thing is that you mentioned it's white and much easier to hide blemishes.
Old Feb 13, 2007 | 08:03 AM
Dirty K's Avatar
Dirty K
How much is that 3M material compound costing these days? Are there cheaper alternatives?
Old Feb 13, 2007 | 12:12 PM
Indy_Gearhead71
It ranges anywhere from about 20-25 a quart, but a quart will last you an eternity unless it's something you use all the time.
1975MudRat
Paint & Bodywork
Feb 7, 2013 12:11 PM
phoneman91
Oct 7, 2011 05:27 AM
56panelford
Nov 22, 2007 12:29 AM
mzimmers
Paint & Bodywork
Sep 5, 2006 02:09 PM
