turbo
Old Feb 13, 2007 | 07:29 PM
OfficerDangle's Avatar
OfficerDangle
thats funny, u wouldnt happen to work for dieselpower products would you?
Old Feb 13, 2007 | 07:31 PM
crosbo's Avatar
crosbo
Thanx for the additional info Ernest.
I have plans to either change out my turbo wheel or upgrade the turbo altogether this spring. Funny, I keep saying I'm going to do all sorts of repairs/mod's this "spring", but in comparison to Idaho, this S Texas weather is spring...and on some days like summer in Idaho. Guess I'm running out of excuses.
I wonder if anyone has ran any tests (other than SOP data) on the difference between running a pre-99 versus post-99 wheel...as well as data addressing the affects of running the TAG units?
Old Feb 14, 2007 | 01:25 AM
ryaneverk2's Avatar
ryaneverk2
How could the TAG possibly help with power on a direct injected diesel? The TAG, "throttle body spacers," and other similar vortex devices might be beneficial on a gasser where the swirling air can help mix in the fuel better for better burning. But on a direct injected diesel, where all the air is already pulled into the cylinder and crammed into a tiny space before the fuel is injected, how can such a device be beneficial?
If the argument is that it helps your turbo pull more air (as in you are now benefiting from more air, because you were a bit heavy on fuel before), I'd argue you need a less restrictive filter or a bigger turbo, or need to check for boost leaks.
Maybe I don't quite understand the concept behind the TAG for our trucks...
Old Feb 14, 2007 | 12:39 PM
ernesteugene's Avatar
ernesteugene
ryaneverk2, My "water down the drain" analogy on the previous page is the best explanation I can come up with. If the air entering the turbo inlet develops a vortex like my wide open sink drain does, then less air flows in. I know my sink empties faster with the diffuser on the drain than without it. In any case, I think my problem was that the variations in air density due to the vortex caused the load on the compressor to vary with a fractional second time constant, which in turn caused vibration loading on the turbo thrust bearings. At least that is what it sounded like to me, as if someone had a hold of the compressor and was rattling it against the bearing cage.
Countryboi
Appearance & Dress-Up
Apr 3, 2016 03:49 PM
Willk98k
Mar 23, 2015 09:04 PM
d-day
Jan 21, 2015 12:42 PM
brokeasajoke
Jul 18, 2014 09:47 PM
fordhorse
Jun 19, 2014 05:35 PM
