Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
How many satisfied F-series owners out there?
Old 01-10-2007, 07:32 PM
linkinluver07's Avatar
linkinluver07
linkinluver07 is offline
What is the mileage and what repairs (if any ) done on your truck. i just want people who browse thorough this forum (Especially the 6.0 forum ) and see all the problems to show them that are is a signifigant number of Fords with little or no problems!
I'll go first just purchased a 2006 F150 and couldnt be happier and in my choice. best truck ever built in my opinion. so cant really comment on how it'll be in future
Old 01-10-2007, 07:36 PM
Red Star's Avatar
Red Star
Red Star is offline
2005 F-150, I bought it brand new. 3,600 miles on the odometer, no problems.
Old 01-10-2007, 09:04 PM
OSin86's Avatar
OSin86
OSin86 is offline
I'd hope no problems!
My first F-series was a 93 F-250 2x4 with the 460 and E4OD trans. At 168K the E4OD went out and since the 460 was buring a quart every 300 miles I replaced both. I was towing construction equipment by this time and it only took 20K for the trans to go again. It was a salvage so who knows what happened. The 3rd E4OD went out in the next 15K so I then installed a C6 (bought for $200 unlike the thousands I was spending on E4ODs) and it worked flawlessly untill the day I sold the truck. I ended up selling the truck because it was now at 200K+ having nothing but electrical problems.
My next F-series was a 77 F-250 2x4 with the 460 and C6 trans. At 86K I found it in a barn in Iowa. It had plywood scrap for a floorboard when I found it. I welded in a replacement floorboard, replaced the clogged radiator, beefed up the rear suspension and installed 3T pump hoist. This was by far the best Ford truck I ever owned. I beat it day in and out for work including hauling a mini backhoe to jobs. It was great. Then some jerk T-boned it and bent the frame pretty bad.
My last F-series was an 85 F350 DRW with the 460 and a 4 speed MT. At 146K I bought it in a HURRY to replace the smashed up 77 so I could get back to work. This truck was nothing but a money pit. Everything from broken body mounts to snapped rear leaf springs. I bought it dirt cheap so you get what you pay for. This truck made it another 20K and then spun a cam bearing. Today it's being recycled for a better life.
Moral of the story, if it's a high milage truck with a dealer spit shine (the 93) or its a dirt cheap farm truck (the 85) you might want to keep looking. Between these and my last BII I'm done with high milage Fords.
Old 01-10-2007, 09:15 PM
Red Star's Avatar
Red Star
Red Star is offline
Yeah, me too.
Old 01-10-2007, 09:17 PM
taisa899's Avatar
taisa899
taisa899 is offline
love my truck. originally it had the 4.9 in her and never had a problem with 233 000kms on it. Only swapped out the motor cause I wanted a 1/4 mile truck!
Jim
Old 01-10-2007, 09:28 PM
tdister's Avatar
tdister
tdister is offline
99 F150 4.6 auto 2wd ext. cab. pushing 165K miles
Alternator (at 145k miles). It didn't die, but was showing signs.
Battery (at 6 yrs. old)
Brake light switch
CC recall
Ball joints and tie rods (one Ball joint was bad for sure, replaced everything while I was down there) this almost fall under normal wear and tear to me.
Front speakers were distorting, replaced them all.
Passenger signal mirror glass fell out when a box hit it, both replaced/upgraded under warranty...somehow (before I bought it).
About to replace windshield due to pitting.
just normal wear items (brakes shocks bulbs etc.) and normal maintenance besides that. A few upgrades as well, but they weren't needed, just wanted.
Gotta stop posting in these threads, I feel like I'm cursing myself .
Old 01-11-2007, 09:11 AM
catan70's Avatar
catan70
catan70 is offline
Count me in '02 f150 w/0 problems and 52k my old man got rid of his '97 w/130k and was runnin perfectly. wouldnt own anything else especially a chebbie.
Old 01-11-2007, 10:03 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
1994 F-150 4x4. Once it turned 100K it was straight downhill. The 5.0 choice was a mistake, as there was no torque to speak of with 3.55 gears, making the climb up this mountain miserable. Fragging E4OD's and rear axle, oil leaks, coolant leaks, cracked plastic disc brake pistons, corroding battery and starter wiring. I did not do heavy towing or otherwise abuse it. Mileage was in the 10-15 range, way below the 15/18 EPA estmate. I test drove a 2004 and it felt just as weak on power, so it was a no-sale.
Jim
Old 01-11-2007, 10:40 AM
Bagger's Avatar
Bagger
Bagger is offline
2005 F250 v10 4.10 auto cc 35,000 miles. So far it has been a great truck!
Old 01-11-2007, 10:56 AM
89300L64x4's Avatar
89300L64x4
89300L64x4 is offline
well ive had my 89 F150 300 efi sence i stared driving and it had 160000 miles on it wen i got it. ive run the **** out of it ever sence and it should've and done alot to fix it too but its normal and some abonormal stuff. its got 177000 on it now.
Old 01-11-2007, 11:54 AM
xtrford's Avatar
xtrford
xtrford is offline
02 F150 4x4 scab 5.4l, been excellent for me so far, only problem was a false ABS code that had to be cleared ($50). A little underpowered but reliable!
Old 01-11-2007, 12:12 PM
never2big's Avatar
never2big
never2big is offline
Bought a '03 PSD 7.3 brand new and the only problem I have had was the crank sensor went bad and the truck would not start. It was under warranty so no biggie. I have 70k miles on it now and I would drive it from coast to coast and not bat a eye. I am very pleased with my rig.
Old 01-12-2007, 02:37 PM
V10_Cougar's Avatar
V10_Cougar
V10_Cougar is offline
Bought a 1999 F250 V10 4x4. No problems. Only a alternator. The monster radio bumping sound killed the alternator. You know 1000 watts fosgate Amp will do it to you. My lights started dimming. Bought a new alternator for 200 bucks and a Capacitor 1 farad for 80 bucks from Fosgate and Bam,,,no problems...Radio is bumping loud...Wife hears me down the street when i'm coming home from work.
Old 01-12-2007, 06:05 PM
DaMole's Avatar
DaMole
DaMole is offline
We got a leasing company and our fords are
2, 2005 F-150s 40K - No problems at all
2006 F-150 20K - No problems at all
2003 Exscursion 6.0 50k - No problems at all
2005 F-250 6.0 50k - Only thing one sensor gone bad
1999 Ranger 90K (For Sale) - only thing is GEM Module
Just sold a 1998 Ranger 90K - No problems at all
1993 F-150 150K - battery, alternator, starter, steering wheel, and oil change, Runs awesome
also have
2005 chevy 2500 Durmax 40k - no problems but does not ride, drive, pull, or look anywhere as nice as the F-250 but got a good deal and customer liked it.
2005 Surburban 40k - has been to the dealer over 15 times with problems
2005 Chevy avalance 30k - No problems other than 3 recalls
and a couple more vehicles.
Ford has got our other trucks beat in performance and realiablity 100% just my 2-cent. Now that ford has the expedtion El when the suburbans 3 years is up we are moving to that. I only wish they still made the exscursion.
Old 01-12-2007, 06:29 PM
nobrandx's Avatar
nobrandx
nobrandx is offline
Talking
I bought a 92 Ranger with a 4cyl and 5 miles on the odometer, at present, my ex-wife still has the truck and it has 350, 000 on the clock, my uncle's 86f-250 with no shocks, tired beat up body and suspension has 300k on the odometer, and that's not counting the 2 years the speedo was broken until he got it fixed. This old truck still runs good (460, 4sp) it still pulls out chevy's in deep snow, his boat and hauls his 13ft slide in old camper, I think I'll send this truck in for a commercial, I see missle field Ford expeditions and f-350's with a 5.4 liter v-8's with an average of 200-250k miles on the odometer with just normal maintenance, my old 1990 f-250 had 150k when I sold it to a rancher in east Glacier MT and it is still being run to this day, at present my 2000 f-350 7.3L has 138k on it and my 1999 Expedition has 120K on it and runs like a clock, I just perform routine maint. on it. I'll always own Fords!!!!
Quick Reply: How many satisfied F-series owners out there?
