Plug Blowout Story
Old 02-05-2007, 12:22 AM
Bobasaurus's Avatar
Bobasaurus
Bobasaurus is offline
Plug Blowout Story
9:30pm a few days ago plug #4 blew out of my F-150 leaving my wife and daughter on the side of the road in sub freezing weather.
Yes, I spent the $400.00 and put a timesert in during the superbowl, but good god what a pain in the rear and now the wife is afraid of the truck.
I bought the truck used so I do not know the complete history. I changed the plugs @ 80000 miles. Torqued them to spec. and used some anti-seize. Still some 12000 miles later it popped a plug and stranded them.
I have read all the check the plugs, re-torque, proper maintenance, alloy vs steel expansion threads and I can tell you that even if you do all the correct things you can still be left stranded by Ford's bad design choices.
I may have to sell the truck as I just can see driving around a timebomb or maybe just buy more inserts and do all 8.
Thanks for letting me vent,
Bobby - The disgusted.
Old 02-05-2007, 07:49 AM
3-RANGERS's Avatar
3-RANGERS
3-RANGERS is offline
Arrow Spark Plug Blowout
Hello Bobasaurus, Sorry to hear that this happened to you and your wife. Especially during the cold weather. It seems from what I have read about this problem that the helicoil is the best and cheapest answer to this situation. At least until Ford decides to acknowledge that there really is a problem with the head design that is...Joe
Old 02-05-2007, 09:13 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Not to sound like a *****,but that's where you screwed up.
JL
Old 02-05-2007, 09:16 AM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
when these things BLOW, are the threads always so trashed you have to retap? (or Helicoil, etc)
Old 02-05-2007, 09:31 AM
Johnny Langton
No-in alot of cases people assume that they are and buy the timesert/helicoil setups for repair when it likely didn't need it. I've seen them just simple vibrate loose from improper installation or from resonance due to detonation.
JL
Old 02-05-2007, 09:36 AM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
JL
Thanks...I'm just hoping my dealer knew what he was doing....
i have too many projects lined up for this spring...gotta have the truck to work on LOL...
some minor surface rust i found...
Old 02-05-2007, 09:37 AM
7700Rob's Avatar
7700Rob
7700Rob is offline
JL
Elaborate.
Old 02-05-2007, 09:42 AM
Johnny Langton
Originally Posted by 7700Rob
Elaborate.
What kind of torque wrench was used?
Was it used with an Extension?
When was it last calibrated?
Do I need to go on?
Torqueing plugs in an aluminum cylinder head-especially with the crappy angle that's required for the #4 and #8 plugs is asking for trouble. Inaccuracies due to deflection of extensions,angle of pull,and miscalibrated or poor quality wrenches is a major problem.
JL
Old 02-05-2007, 10:24 AM
dkoenig's Avatar
dkoenig
dkoenig is offline
Bob, for about 4 months I had a ticking noise that I assumed was an exhaust leak. Well, it kind of was, it was my #4 plug working its way loose. It never blew (THANK GOD!). I am a little auditorily paranoid about my vehicle, so the ticking drove me nuts till I finally tracked down the issue.
Do you know if you vehicle was making any kind of noise like that prior?
just curious.
Don
Old 02-05-2007, 10:32 AM
3-RANGERS's Avatar
3-RANGERS
Exclamation Spark plug Torque
Do I need to go on?
JL
What is the torque supposed to be on these JL?
What kind of torque wrench should I use?
Does the extension change the torque some how?
What about a universal joint to reach #4 and #8...Will that have a bad affect on the torque?
I will have to do mine soon. Thanks, Joe
Old 02-05-2007, 11:16 AM
Johnny Langton
I won't use a torque wrench on any of my modulars-there's too much of a chance to damage or strip the threads. Extensions will change the torque value-they flex upon torsional force,and can alter the torque value that you'd get with a torque wrench. U-joints in the mix make that problem even worse.
You just have to get a good feel for it after the plug stops-attempting to torque them usually results in stripped threads-especially in aluminum heads.I've seen it alot,and not just on modulars.
JL
Old 02-05-2007, 02:57 PM
sysman_rick's Avatar
sysman_rick
sysman_rick is offline
Ford's torque values are for dry threads,NO antisieze.
Old 02-05-2007, 06:26 PM
Bobasaurus's Avatar
Bobasaurus
JL,
I have a Craftsman clicker type wrench. I calibrated it at work about 6 months ago. It was fairly accurate at 10/20/30 lbs ranges I checked.
I was using a 2.5 inch extension that should not flex much with the mighty 13 foot pounds of torque these whimpy 4 thread heads allow. I have been wreching for a good 30 years so use of equipment is not the cause. The anti-sieze changing the torque value may be a source I did not consider.
sysman_rick - good point. I don't know a good way to account for that variable either. I'll have to ponder that for a while. No- Seize may be in the next round of plug changes.
3rangers, I went with the timesert BIGSert system to get a full sleeve insert. I did not trust the wire type threads of a helicoil. It sounded like trouble again somewhere down the road.
I still blame FORD for the stupid number of threads in these heads. I have never, not once in 30 years, stripped out or damaged a plug thread before. And that is a lot of threads in a lot of heads of many manufactures and metals. That includes the aluminum heads in my 177K miles Ford Contour which use exactly the same plug that I have changed out 3 times.
Bobby
Old 02-05-2007, 06:39 PM
Johnny Langton
JL,
Bobby
I'm not questioning your abilities at all,but using a torque wrench is always the first thing I hear when somebody tells me that they have blown out a plug. One other variable that I never see discussed is the resonance from detonation(even light detonation that you can barely hear) loosening the plugs,and when that happens-over time they're gonna work themselves loose and pop out. I've never seen a modular in a truck that doesn't detonate at one time or another-the OE calibration adds spark advance if the knock sensor isn't triggering and indicating detonation.
JL
Old 02-05-2007, 06:49 PM
Bobasaurus's Avatar
Bobasaurus
I do get some what I call "spark-knock" detonation occasionally. I will be checking the plugs more often now for tightness.
What's kinda funny to me about the torque wrench is I had gotten to the point of not using it on iron heads because of the tight areas in my Mustang and Cobra, but as I read about this truck and all the plug problems I went to the torque wrench to make absolutely sure of my value and now that change along with the antiseize may have added to my problems.
Live a learn.
Bobby
