E4OD Problems/Questions
Old Feb 4, 2007 | 07:32 PM
Fal Grunt's Avatar
Fal Grunt
So last night I blew a line going to my tranny cooler. I drove probably a mile or so before I got where im going. The trip was short from my apartment to my girlfriends. You can see a huge trail of fluid down the road from about 100ft of my apartment almost all the way there. It pretty much trickles out to a still solid stream but probably only about an inch wide.
Anyway.... wondering what all I should do. I obviously fixed the line and put new fluid in. However today it was driving terrible. When I accelerate it literaly fights to accelerate. It feels like something is binding/resisting. I have to accelerate much harder to get the truck to accelerate.
Im wondering... did I get too much tranny fluid in? I used Dexron III/Mecron because that was ALL that was available and I needed the truck to haul some stuff this morning.
Or did something detrimental happen? Checks?
-myers
Old Feb 5, 2007 | 01:13 AM
Fal Grunt's Avatar
Fal Grunt
Tonight I noticed that the tranny would engage with no noticeable feeling. Normaly there is a little bit of a buck and clunk when the tranny engages into D.
That and I noticed that when accelerating, I would keep RPM's at a constant, but would feel the truck slightly accelerate like I gave it more gas, and then slightly drop out like I let off.
I would like to note that it is currently -1F and -15F with the windchill, and 9mph gusts. I spose this could be a part of it... as almost all of my driving has been for less than 2-3 minutes, the truck doesn't even approach operating temp.
-myers
Old Feb 5, 2007 | 06:27 AM
slc10844's Avatar
slc10844
Sounds like there is internal damage. A transmission shop is the best place to get an assessment of how bad.
Old Feb 5, 2007 | 06:17 PM
mhg's Avatar
mhg
have you rechecked your fluid level
it may take 3 times adding to get it full
Old Feb 5, 2007 | 07:33 PM
Fal Grunt's Avatar
Fal Grunt
I put 2 gallons of tranny fluid in, I havn't checked it agian today. I'll check that.
-myers
Old Feb 5, 2007 | 07:52 PM
mhg's Avatar
mhg
these can hold up to 17 quarts
over 4 gallons
Old Feb 5, 2007 | 08:01 PM
Fal Grunt's Avatar
Fal Grunt
Yea, the Ford dealership Powertrain manual I have states that the E4OD takes 16 quarts, I'll check agian, but having put the fluid in, running it for awhile then check I assume it had time to settle down.
I'll check tomorrow after warming up.
-myers
Old Feb 6, 2007 | 01:14 AM
rick_369's Avatar
rick_369
start it put it in neutral, If it try's to move forward, You burned up the intermediate clutches, they've basically welded them selves together.
Collin McMaster
16
Feb 21, 2017 10:00 PM
drumdude
Sep 2, 2016 12:16 PM
BT7800zz
Jul 22, 2016 03:17 PM
jared.t.l
1978 - 1996 Big Bronco
Oct 4, 2014 09:26 AM
superduty4x4
Aug 4, 2008 04:29 PM
