??Fill Plug Borg Warner 1356 Mechanical T-case??
Sorry, real stupid question. Anyone know where the fill plug location is on the Borg Warner 1356 Mechanical t-case? I have several shop manuals and searched the web, but see nothing showing the location. All other t-cases in the manuals show the locations but not for this t-case (also its not marked on the casing either). From looking at it, I think the fill plug is located on the reverse side of the t-case and towards the top where the rear shaft enters the case but unsure. I couldnt take it out as it appears the inside head of the allen bolt is rounded out and had no time to mess with it yet. Also, I think the seals have a slight leak so I bought a 24oz bottle of leak eliminator ATF fluid. Would adding this to the recommended Dextron ATF fluid have any negative effects on the t-case? Thanks a lot in advance.
Happy Holidays.
Happy Holidays.
