97 F250 4x4 460 MPG
Try 9-12 gals per mile. no my 95 f 350 460 4.30 rears srw gets about 7-9 in town a little bit better on highway.3 in 4x4 plowing.thats about avg. its stock. one reason i got the diesel better mpg. 460 is a great engine been running since 94 no problems except b.s .theres a topic in the 87-97 ford larger trucks forums,about mpg. you should be about your numbers a little less towing,these engines are thirsty when working.
Originally Posted by kmccune
Thanks, I am a little leary of it, because all I've ever heard was 8 mpg towing, hauling, unloaded highway ect... It didn't seem right but???? But its also got a pretty good rep for performance and life.
Thanks again
Thanks again
I bought a 93 F250 460cid, 4x ext cab long box with the 3.73 ls diff and 31" tires, awhile back to add to the work trucks and we took it to chicago to pick up a plow for it, I averaged 12-13mpg running with cruise at 75mph.
Back home it's done nothing but haul heavy stuff and push snow. in town hauling I still average 9-10mpg and pushing snow....dont ask, this is one thirsty sum beeotch to say the least. My 2000F350 V-10 does twice the pushing in a day then the F250 and i drop 1/2 tank with the 350, the F250 is bone dry by days end.
i have noticed no difference in mileage on my 05 v10 than my 93 460.the 05 has alot more power and is WAY more comfy.still has a payment too
Both trucks are similar total capacity for fuel, and my '00 F350 will typically only burn half tank the entire day/eveing plowing vs the F250 guzzling down BOTH tanks and ready for fuel by nights end. I thought it might have been the guy in that truck so I took it out one afternoon and with each push I watched the gauge go down....not literally, but in the lot I started that afternoon with, only takes approx 30 minutes to push, granted it was 4" deep with ice crust on top, but I used over 1/4 tank on the rear tank. drive it normally without blade on and sand/salt in the back and right back to 10-12mpg she goes.
Everything else the 2 are comparable mileage wise, except when pushig da snow. Throughout the day I'm sure the driver has much to do with it as well since I've been doing this for years and my brother who I put in the other truck, not so much, and I'm sure like most guys that get in a plow truck it's as hard as it will go 150% of the time in total disregard, even though I've lectured him on this fact. But that day I drove it/plowed with it, once I was done I was half temped to see if there was a hole in the tank LOL!! I know the tires on that truck are just some stupid mudder type tires with zero sipes so you have to get wheel speed and momentum going to push long runs, where as the F350 has new tires with lots of sipes and I usually have 3000lbs of salt or sand in the back spreader so you can just ease on down the rows no matter what's in front of it.
Then too, the F250 I have turkey wings on it, essentially making it a 8'6" box plow so nothing really windrows as it all goes forward, so it's nothing to have a pile of snow accumlating higher than the hood by the end of a push, requiring more throttle to keep that amount of mass moving....where's as the V blade on my F350 can only make a roughly 6' V when in scoop mode so I guess I'm not catching near the snow the other truck is.
