Welding Question
I have never welded a axle tube before. Is there a better rod for this use? I use ones that they call a farm stick. It can be used on thick and rusty metal.I weld my Plow and body in the old steel bump trucks and repairs around the shop.The mig is for thin metal and I have not used it much.Is the mig able to weld the plates to the axle?
If you're going to use a stick welder, I would use a 3/32 or 1/8 7018. A mig will work if you have a good mig welder thats capable of welding that thickness, I'm guessing somewhere around 1/4"? Having some experience with it would'nt hurt either. Being a welder/fabricator for close to 30 years this is about the only area I can give an educated guess, where I lack is turning a wrench.
Charlie
Charlie
Sam,
With Jesse's(Farmboy Fabrications) bars, the tabs for each bar are welded on. His buddy Joe did the welding for him since his mig welder was down. He used sticks and it came out just fine. Proper prep will allow for things to go smoother. The cleaned up the area with a grinder before he started to weld. Wish i had a closer up picture for you but this is the best I have.
I want to get all of the planing covered. The 6" lift kit will have blocks in the rear. I want the springs from the factory. I put add a leaf on a 3/4 ton truck with a lift kit and the ride was bad! Traction Bars are to eliminate axle wrap due to the rear blocks. Stainless Steel Brake Lines front and rear. I did a 1998 F250 and I was not impressed with the results so I want to get it right on my F350.
TireJockey
06-28-2013 07:47 PM
twisted289
02-12-2007 04:47 AM
generalee31184
1999 to 2016 Super Duty
26
04-10-2006 08:43 PM
