Oil & Lubrication
diff oils
Old Jan 28, 2007 | 05:34 PM
muddytires's Avatar
muddytires
diff oils
Im looking for what diff oils i should use. What weight, a good brand ect. The rear diff im not sure about. Its on a 2002 f-250 sd 4x4 with a 5.4 liter. Not sure which rear end it is and how to verify which it is. Any advice would be helpful. The same goes with the front diff
Old Jan 29, 2007 | 06:31 AM
Torque1st's Avatar
Torque1st
Posting Legend
Try the oil and lube forum.
Old Jan 29, 2007 | 09:21 AM
firesoutmatt's Avatar
firesoutmatt
Look in the owners manual . They have all these great secrets listed.
Old Jan 29, 2007 | 11:19 AM
TallPaul's Avatar
TallPaul
The manual will tell you the weight, but for brand I would go with Redline. Also even if the book says 75w90 you may be better off with 75w140. Remember these numbers are a different scale from motor oil and a 75 may be like a 30 weight--don't know exactly, but you can google and find out.
Old Jan 30, 2007 | 11:16 PM
Big O Dave's Avatar
Big O Dave
I second TP's recommendation for Redline. I would also like to add Chevron Delo Gear Lube to the list, if you're not gonna go synth.
Old Jan 31, 2007 | 07:13 AM
projectSHO89's Avatar
projectSHO89
There is a tag bolted to the diff cover that gives your spec.
It likely says "75W-140 SYNTHETIC". Follow it specifically. If your axle is limited slip, add the correct friction modifier if not present in the base replacement oil.
The brand name is your personal choice. One is likely as good as any of the others as long as it meets or exceeds Ford's specification.
Steve
Old Feb 4, 2007 | 05:09 AM
PW01's Avatar
PW01
My Ranger (8.8, 4:10 gears, LS) calls for 80w-90 for both front and rear differentials. Would there be any benefit to using 75w-140 Mobil 1, or would I be better off using the 75w-90?
Old Feb 4, 2007 | 01:57 PM
99F150's Avatar
99F150
the 75W90 synthetic will work great, but the 75w140 is said to protect better when towing heavy loads.
Old Feb 4, 2007 | 03:52 PM
aurgathor's Avatar
aurgathor
For the rear axle, you should use 75W-140. For the front, you could use the lighter 75W-90.
Old Feb 5, 2007 | 01:23 AM
muddytires's Avatar
muddytires
Well i know the rear diff on my 02 f250 has 2 tags . Ill take another look tomarrow to see if i can read them at all. Hopefully itll give me the info im looking for. The transmission calls for regualr mercon. However i remember ford came out with mercon v to rid the problem of shuddering in the trans. Im know i should use reg mercon. But why would they come out with a new fluid for my truck to use the old fluid?
Old Feb 12, 2007 | 10:01 PM
hosenturf's Avatar
hosenturf
Additional question,
From what it sounds like, if I have a factory limited slip that originally didn't have synthetic, and I and a quality synthetic it would be ok as long as I add the correct friction modifier to it?
Old Feb 13, 2007 | 01:11 PM
PW01's Avatar
PW01
Yes, although some synthetic lubes claim that no modifier is needed.
Old Feb 13, 2007 | 01:37 PM
aurgathor's Avatar
aurgathor
I personally found that regardless of the claim on the bottle, I needed the friction modifier.
