Help on glow plug relay wire harness
Old 01-28-2007, 11:08 AM
BigCajun54's Avatar
BigCajun54
BigCajun54 is offline
I have a 1997 F-250 7.3 and I would like to know if someone can help with my problem. On my glow plug relay exterior wire harness were it connects to the valve cover, I have a couple of burned spots on the plug. I know I have to change the fuel charge wire and glow plugs under the V/C but, my question is do I have to change the whole exterior wire harness are is there a kit for the plugs on the ends of the harness? I only have 1 plug-in out of the 4 plugs on the harness that has 2 of the pens that are burned.The harness is very costly. Would like to know if I can get out of buying the whole glow plug relay wire harness. It seems that there would be a way to fix this problem with having to change the whole harness. I heard it cost anyware from $400.00 to $600.00 bucks.
Thank, BigCajun
Old 01-28-2007, 12:50 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
You can find most PSD parts #'s here:
http://www.thedwilsons.com/powerstroke/PSD_Part_Numbers.html
I copied the following from that site:
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Old 01-29-2007, 08:25 AM
BigCajun54's Avatar
BigCajun54
Jim thanks for the help. You have saved the day for me not to minchin the big $$$ bucks for a whole new wire harness.
Thanks again.
BigCajun54
Old 01-29-2007, 09:14 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
No problem! If you need more info check back here. Best repair info on the 'net.
Take a look here for more info:
http://andersonimprovements.com/hobb...sandrelay.html
bluef10069
01-03-2017 04:24 AM
tgreening
02-29-2016 12:07 AM
crewchief219
08-19-2013 12:51 AM
arkredneck
11-28-2008 12:54 PM
Drover
04-14-2005 10:36 PM
Quick Reply: Help on glow plug relay wire harness
