Frame is done, I think :)
What is needed for the rear spring hanger (assuming it is bolted on the bottom to an L-bracket) is a beam running under it. The horizontal leg of the L-bracket will just bend if there is a crossmember inside the frame alongside it.
A frame rail that is boxed and 2" deep will be a little less than 2/3 the strength of a C-channel 4" deep. The stiffness of a channel goes up as the square of its depth. What you've done is pretty much the standard hot-rod modification, which I personally have an engineering issue with. Depending how how fore/aft you boxed, you may or may not have problems down the road.
Not trying to rain on your parade, but I hate to see suspension mods that could be dangerous. If you aren't going to carry loads, or drag race, or tow with it, I may be worried about nothing.
The boxing plate is 13 inches long and is 3/16ths. It will not be used to tow or haul anything heavy.
A regular spring hanger has an L bracket built into it and would put a moment about the frame rail the same as my L bracket. I am just hopeing my L bracket can handle the internal forces. Mine is further back from the crossmember so the frame would have take up some more twisting. Might as well move it back some.
The other bit of fun with the new springs is the rear portion of the spring is longer. The spring is 56 inches long and the axle is 24 inches from the front hanger. I beleive this makes 57% of the load go up front and 43% out back right? That should help me some with the c-notch and the twisting force put into the rear portion of the frame.
I appreciate the input, its been a few years since I took all those ME classes
Another option might be to use some doubler plates in conjunction with boxing the frame to spread some of the load back there. It's not the most structurally efficient or cosmetically appealing option, and you may not be able to get back all of the frame strength but I think you could get back a lot of it considering that the original frame isn't all that thick to begin with,
Didn't the drag racers use springs set up like that (more of the leafs towards the front) to help eliminate axle wrap on hard starts? It seems like I remember something about the MOPAR guys calling them Super Stock springs or something along those lines.
......I could be wrong here......
On my 49 I moved that rear x-member all the way to the rear (mainly to accomodate the fuel tank) I did add some additional x-members (again, mainly for fuel tank mounting) but they will definately provide some stability.
Bobby
Bobby
Bobby
Bobby
I dunno I think the front takes the bigger brunt of the action, most leafs I have dealt with the front bushing is twice the size of the rear one.
As far as reinforcement, Ax's sketch is the ideal; if you don't have the clearance to do that, you can add plates on the top and bottom flange. That gives the most strength per pound of metal added.
Ax I am sure you have forgotten more than I know
I agree that the rear will be flexing more, but its a longer lever arm so less force should be needed to keep it in place. The front of the leaf locates the axle more and like you say takes the hit more on bumps and what not.
Certainly safety is paramount but chances of the rear shackle bracket sheering is very low worst case scenario it would turn into a V and I would have some tweaked leafs.
The C-notch I see being a problem if I put a 1000 lb tongue load on a trailer hitch. Heck I probly improved my safety in case of a rear end collision, it might actually give me a bit of crumple zone
on
Yes its boxed, should theoretically be as strong as stock.
Vern how far forward do the bumper brackets go, I guess I may as well move it back.
Bobby I know I am sorry I will get right on it
My truck is stored for the winter so I can't get to it right now. As I remember the bumper brackets go in about 5-6 inches. You probably should have them loosely bolted on before you move the crossmember rearward. My 48 is an F-3 and I had to cut 12 inches of frame off the rear in the shortening process so my frame might not be the best thing to take measurements off of anyway...
#28
#29
on
Gary,
Having just c-notched my frame I highly recommend you need to reinforce the notch by adding depth as shown in Ax's diagram. I just welded in a section of the 2X2 crossmember, which I had removed from the frame, to the top of the frame. Since you have to bump up the bed for the rearend already this shouldn't be a problem.
Secondly, while the front spring perch takes most of the fore/aft loads, the rear takes the all vertical load of the rear of YOUR truck (deadload) not just the load you put in the bed (liveload). The combined dead and live loads will cause the rear frame to twist if not restrained and will fail over time. If my memory serves me right weren't there crossmembers very near both the front and rear spring mounts? I would suggest you move the rear crossmember back as close to the rear spring support as you can. I moved mine back to enable placement of the gas tank, where is your gas tank going to end up?
#30
Here's how it lays out; assuming truck weight and fore/aft distribution, you can figure out the forces sitting still on each end of the spring. These forces will double or triple on the road due to bumps, railroad tracks, etc. This is because the axle and truck have to be accelerated upwards over a bump, and are brought back down by gravity very quickly.
