EBPV tube
EBPV tube
I just removed the tube going from the EBP valve to the manifold and about halfway down the tube it had a rusted out hole in it. I guess the valve sucking air would explain why it hasn't been running so hot lately. I replaced the CPS last month. (the people who are manufacturing those CPS's are filthy stinking rich! I smell a conspiracy)
Anyone else have that happen?
Mine was rusted. My holes in the tube were so small i found them by accident when i put some compressed air through the tube when i was cleaning it out. By luck I had a finger on the other end of the tube with some brake cleen in the tube as i was shooting air in it. I saw these bubbles coming out of the tube through tiny pin-holes. Replaced it and the sensor.
As for the CPS you know where i stand!
Originally Posted by Gradymeister
Does any parts store carry that tube? .
All the parts houses around my area didnt carry the tube. A&A auto parts had the sensor but it was at the warehouse.
Beware PMS may insue after reading the following!!!
If you ever plan on running an blank turbo pedistal or gutting yours, or disabling it in the future, here is a way you can save some money by not buying new parts that you may not need in the future.
If you do not use, or do not plan on using your EBPV flap for braking, read on. If you need it read below. Maybe you can save yourself some money in the future if it applies.
1) you can cap off the outlet at the manifold.
2) you can go to dfuser.com and get the code eliminater for the ebpv sensor(site sponsor)
3)you can order your ebpv blank pedistal from e-bay $99 (Rons turbo shop)
No more leaky EBPV. You can upgrade your turbo exhuast flange outlet to one that is less restrictive. No more ebpv sensor malfunctions. As you can see i went through the same thing you are at one time.
So if I buy the eliminator and just plug it in and cap off the hole in the exhaust manifold I'm done with the EBPV problem forever?
