03 explorer heater
Old Jan 25, 2007 | 06:49 PM
Outlawwv's Avatar
Outlawwv
03 explorer heater
is the heat supposed to blow out on the floor when the defroster is on -- and yes i've got it on defrost and not mix or bi-level
Old Jan 25, 2007 | 07:26 PM
JerrySimm's Avatar
JerrySimm
I'm pretty sure my '03 does not do that. Does air come out the defroster as well?
Old Jan 25, 2007 | 08:23 PM
Outlawwv's Avatar
Outlawwv
yeah and the heat that comes out on the floor will melt your shoes (not really) i'm thinking it may be a vaccum line or other control gone bad -- i bought a warranty when i financed this thing maybe it's time to try it out as i seem to have 4wd issues also
Old Jan 26, 2007 | 06:49 PM
JerrySimm's Avatar
JerrySimm
Kinda sounds like either a blend door issue or something with the control, or a vacuum leak, like you said. If you've got it warrantied, I'd definitely go that way.
Old Mar 13, 2010 | 05:27 PM
mwkobe's Avatar
mwkobe
did you ever figure this out im having the same problem?
Old Mar 13, 2010 | 09:05 PM
steve(ill)'s Avatar
steve(ill)
vacuum controls 3-4 different cylinders that stroke 3-4 different doors. You can send the air to the defrost, dash, floor, bring in outside air, or bring in recirc from the cab back to the heater. There is one vacuum line going to the dash selector switch and it distributes out from there to several hoses. If you have no vacuum, the doors all close and the air comes out the defrost by the windshield. If the air comes out the dash or floor, then the controler behind the selector **** is probably leaking inside.
Old Mar 13, 2010 | 09:07 PM
mwkobe's Avatar
mwkobe
thanks i will try and check that one
wayne
Old Mar 13, 2010 | 09:09 PM
steve(ill)'s Avatar
steve(ill)
look at this drawing... you will get the general idea.
https://www.ford-trucks.com/forums/9...-please-2.html
