Need radiator for a 67 Econoline...
Old 09-15-1999, 10:17 PM
Dumpster Villard
Guest
Posts: n/a
Anyone out there know where I can get my hands on a radiator for a 1967 Econoline? I got the 170 six cyl. motor. Or if you know of a good re-core outfit, that'd work too. Any help at all would be greatly appreciated! Thanks in advance...
Dumpster
PS... If you got ICQ you can also contact me at 1392508
Old 12-12-1999, 06:41 AM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
This is just my 2 cents worth cause I've never had one of these rigs and I don't know if has something special on the radiator, but.....
It looks to me like you might want to measure it out thoroughly and take a walk around a junkyard to see what else will fit physically no matter what brand. Then all you have to worry about is getting creative with hoses. I had a 302 radiator mounted up for a slant six once, worked great. I had to have two seperate bottom hoses with a piece of pipe between them to make the connection because the bottom radiator outlet was on one side and the water pump outlet was on the other side.
Trail Rider
Old 04-07-2000, 09:37 PM
Redbeard's Avatar
Redbeard
Redbeard is offline
I've got a '67 Econoline truck with a 289. I bought a radiator for a '66 Mustang(V-8). Falcon radiators will work also.
Old 04-03-2002, 11:58 PM
rkdickie's Avatar
rkdickie
rkdickie is offline
This is gonna sound really weird , but if you NEED SUPER cooling , a rad from a 990 CASE tractor will fit under the doghouse & is over 3 inches thick.
Old 04-04-2002, 02:37 AM
ke6bnl's Avatar
ke6bnl
ke6bnl is offline
PeeWee525
05-26-2017 12:32 PM
meangreen92
12-26-2016 10:55 AM
Apocalypse
12-21-2015 07:05 PM
HIO Silver
08-11-2015 11:13 PM
poorfatkid
22
12-16-2007 01:22 PM
Quick Reply: Need radiator for a 67 Econoline...
