Generator light on ALL the time...
Old 07-04-2007, 08:39 AM
61Econoline's Avatar
61Econoline
61Econoline is offline
Unhappy Generator light on ALL the time...
never had a generator problem with this truck... now the light came on several days ago... my wife uses the truck to get to work (1 mile away)
'don't have a repair manual, but have checked:
*the battery: 12.67 V - does not change voltage when the engine is revved
*fan belt for the generator: it's tight and it spins the gen.
*the voltage regulator: the bottom "coil" connects to the battery and then pushed in the GEN light goes out, but the voltage does NOT increase (at the battery) when the engine revs
...so, how do I check the VOLT.REG, and GEN to determine which is not working properly? Is there a way of "adjusting" the VOLT.REG.? I'm "in-the-dark" without "maintenance procedures" - I'm willing to fix it, I just don't know how...
Thanx,
Ron
Old 07-04-2007, 07:16 PM
fl1a's Avatar
fl1a
fl1a is offline
You might want to put this question up on the "misc." forum in the electrical systems thread, also.
Old 07-05-2007, 12:39 AM
pfogle's Avatar
pfogle
pfogle is offline
I'd start by making sure that the regulator is grounded well. Take a lead from the battery and attach it to the body either close to or on the actual bolt that holds the regulator in place. If that doesn't fix it then you probably have a bad regulator, or bad brushes in the genny.
Old 07-05-2007, 02:31 AM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
Could be the 'Brushes' need to be replaced, they do wear-out, don'tcha know.
Could be a Connection has come loose in the system somewhere.
Old 07-05-2007, 04:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Most autoparts stores carry new brushes and bearings. The cost is about 20 bucks. As Col Flashman pointed out, the generator brushes are prolly worn down to nothing. When that happens, the generator will not charge.
Shade tree mechanic: The older voltage regulators do stick on occasion. Rap your knuckles on the cover a coupla times, see what happens.
Old 07-06-2007, 02:11 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Here is the brush kit FX34 www.kragen.com but it shows the bearings are discontinued.
Old 07-06-2007, 05:18 AM
NumberDummy
A8AZ-10094-B .. Replaced by >> C9ZZ-10094-A .. Bearing: Generator End Plate (Motorcraft GE-21)*
B6A-10095-B .. Bearing: Generator Rear (Motorcraft GE-4)
*Kragen sez Obsolete? This bearing has also been used in alternators since 1969...and is still used today.
BIL is VP of Checker (Kragen)....mebbe I'll call him up and have him update the info.
Old 07-08-2007, 09:39 PM
61Econoline
'finally had a chance to remove both the volt.reg. and the generator.
after opening up the GEN 'noticed the brushes are worn pretty good but the commutator that they ride on is *R*E*A*L*L*Y* worn down...
'called *every* auto parts store in the phone book: nobody (on a Sunday) has a replacement. Tomorrow I'll start calling "auto electrical" places to see about getting another one...
Suggestions for places to try??
Old 07-09-2007, 04:40 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
yours can probably be turned down and flattend. anyone that rebuilds electrical stuff should be able to fix you up.
Old 07-10-2007, 07:34 AM
61Econoline
Jimbare,
there was no fixing THIS commutator - it was worn down almost 40% !!! I don't know *how* it was working as long as it did... I've had my 61 'Connie since March 1984, rebuilt quite a few things along the way, but the last time I *looked* at the generator was ~1989 when I changed brushes... 'found an "automotive electric" place not too far from my shop and they completely rebuilt it in 1/2 a day !
'have had quite a few cars and motorcycles in this time, but the one "constant" was the '61.
My cousin's girlfriend, back in 1984, named the truck "Homer" - it was *not* good looking (faded paint, bad wheels/tires, etc) and she didn't want to be seen in it... the name 'stuck'...
Old 07-10-2007, 01:49 PM
fl1a's Avatar
fl1a
fl1a is offline
There is a used, pulled 61 Falcon generator on ebay motors for sale. I can find it
again if youre interested.
