Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
I've got brake problems
Old 01-28-2007, 09:54 PM
HawksNest's Avatar
HawksNest
HawksNest is offline
I have a '78 E-150 stretch that I use as my mobile service truck. After I bought it, I put in 3/4 ton I beams, front springs and spring perches, 3/4 ton diff w/3:11 mid-west gears(1/2" studs), 3" 3/4 ton leafs, new perches and an air bag system. THEN after a couple of years of too high a gears, I installed a 3/4 ton diff with 9/16 wheel studs, 3:56 gears and removeable drums. also changed out the front I-beams to match (1985 I think). ANYWAY, when it is slick on the roads or even wet, the front brakes lock up and skid while it feels as though the rears aren't even working....I have to stop with my left foot on the e-brake, my left hand on the release, and my right foot on the brake pedal for the fronts. the brakes are all 100% new at the wheels, and adjusted up just fine, also got lots of e-brake. I'm planning to put a master cylinder from a '85 on there to see if it helps......any opinions or personal experiences?
Old 01-28-2007, 11:09 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Make sure the brakes are fully bled, all fittings are tight, and that the brake hoses are in good shape.
You might also take a look at the proportioning valve, and the master cylinder should be changed to the correct one also.
Old 01-31-2007, 10:05 PM
Placermike's Avatar
Placermike
Placermike is offline
What type of brakes do you have front and back? Ford_Six is probably on to something. You also may have front discs and rear drums. Based on the description, seems like the rear brakes are the issue.
tonymontanna1983
08-21-2016 10:01 PM
aharleycpl
04-07-2016 09:30 PM
Dan_Johnston
1999 to 2016 Super Duty
01-26-2016 07:57 PM
devovino
01-05-2016 03:30 PM
jimbone422
12-31-2012 03:40 PM
Quick Reply: I've got brake problems
