4:30 v. 4:88 '08 F450 tow capacity...
02-05-2007, 05:59 PM
on
Quote:
Originally Posted by Percys Armory
thats how I ended up with ordering a KR
mmmmm....
Think there is a conspiracy I this then?
02-05-2007, 06:34 PM
on
The lower the gear ratio the smaller the pinion gear is... the pinion in the 4.88 gear set may not have met Ford's durability standards.
02-05-2007, 06:36 PM
on
The lower the gear ratio the smaller the pinion gear is... the pinion in the 4.88 gear set may not have met Ford's durability standards, so they reduced the hp and torque. For highway driving I see no reason for 4.88 gears in a diesel.
02-05-2007, 08:32 PM
on
I say yes, now that you mention it.
Quote:
Originally Posted by 1968gtcs
mmmmm....
02-05-2007, 10:17 PM
on
Well According to the order guide it does state that the:
HIGH CAPACITY TRAILER TOW PACKAGE (535)
Availability:
• Optional on all F-450 Pickups
Includes:
• 4.88 Limited Slip rear axle (X8L)
• Increases GCWR from 26,000 lbs. to 33,000 lbs.
• Upgraded rear axle
Can't find the "upgraded rear axle" anywhere in the specs... hummm
Chris
Ryan313
1999 to 2016 Super Duty
12-22-2013 06:44 PM
tgreening
29
09-05-2010 11:00 PM
mregister
09-12-2009 10:20 AM
Paige Haddock
6.4L Power Stroke Diesel
34
05-13-2008 12:18 AM
Big Sky Rancher
42
04-05-2007 06:39 PM
1999 ,
2005 ,
430 ,
488 ,
capacity ,
diesel ,
dually ,
f450 ,
gears ,
high ,
rating ,
tow ,
towing ,
truck ,
upgrade
