2005 Advancetrac problem
Old Jan 23, 2007 | 12:34 PM
jasongt06's Avatar
jasongt06
I have an 05 Exp w/Advancetrac. When i shut the engine off it says "Check Advancetrac" so i take it in they say it is a tsb and they replace the instrument cluster. Well it is still doing it and local ford dealer says they cant find anything wrong and to bring it back when it is doing it more frequently. Just looking for opinions on if i should take it to another dealer or if you have had similar problems. Thanks
Old Jan 23, 2007 | 06:08 PM
Viking2005's Avatar
Viking2005
I have a 05 Explorer too. I have not seen this happen. When you turn off the engine, does the "check advancetrack" come on immediatly after the engine is off and the key is either in the off position or out of the ignition?
Old Jan 23, 2007 | 08:55 PM
jasongt06's Avatar
jasongt06
it happens as soon as you turn the engine off but before you actually pull the key out.
Old Jan 23, 2007 | 10:06 PM
Viking2005's Avatar
Viking2005
Interesting. I will look into and let you know if I find anything out.
Rubiconrod
6.7L Power Stroke Diesel
31
Sep 6, 2016 05:39 PM
folwtruck
2009 - 2014 F150
Dec 26, 2015 07:04 AM
kynnhoj
Aug 27, 2012 06:25 AM
2005Mariner
Apr 13, 2005 05:47 PM
