worried: noise coming from motor
For the last month or so I have noticed a noise coming from the motor I have not heard before. It is consistant with engine rpm and gets much louder as rpm increases. best way to describe it would be like loud gears, as if i had a gear drive timing set. Its a 4.2L with about 120k on it. Just had oil change today and no difference. Any ideas?
I should mention this hasnt cuased any actual problems, the engine still drives normally, and although it is very noticable in first and second gears once the rpms hit midrange, I cant really hear it once I am going 30mph or more since my tires are a bit loud (meaning the problem is really loud or anything like that, but definately noticable).
Yikes... now I am wondering if this is relates to my recent problem with no coolant in my tank. But my oil looked good (no water or not milky lookin). BTW it is a manual, and no problems with power steering thats noticable to me. I'll have to get under the hood again and see if I can better locate the area the noise seems to be comming from.
Thanks for the good tips. I didnt get a chance to look at it on my 2 days off this week so it will have to wait till next monday. Just incase it is possibly serious, I am going to try and drive my bronco to work, but dang its going to be cold with no rear window, crappy heater, and a cold front comming through the next few days! I've been meaning to invest in one of those soft tops, atleast that would fix the no rear window problem I have.
from what u explained i had the same noise coming from my engine so i been paying attention to ur replies. ITs been goin on for a few weeks now, In the mean time, last week i passed someone on the way to work, and while in the passing gear ,the rpms went up to around 4500, thats when my battery light flashed 2 or 3 times, but i have been hearing that noise for several weeks, maybe a couple months, so i changed the alternator becuz of the battery light flashing, and Surprise ! the hum which made my truck sould like it was gear drivin, is fixed also. I dont know if u already fixed it so thought i would pass it on. When i took the old alternator off, I could spin it by hand and hear the grinding by just doing that !! Good luck
