How do I remove heater core?
Old Jan 19, 2007 | 07:04 PM
Keepin It Real's Avatar
Keepin It Real
Howdy. I have a '73 f100 302 c4 2wd and coolant had started to leak from under dash. I've disconnected the coolant hoses figuring I will need to get the core repaired at a radiator shop. Unfortunatly I don't have a clue how to get it out. Somebody told me I had to go through the glove box. All I've succeeded in doing is removing the six screws that hold the cardboard insert in, but the insert won't come out unless I destroy it. That can't be right. I'm sure the whole glove box unit is removable, But I'll be darned if I can see how it's done. Any body here ever done this before? Am I even approaching this right? Any help is appreciated.
Thanks
Roger
Old Jan 21, 2007 | 02:29 PM
Ultramagdan's Avatar
Ultramagdan
I'm not sure but isn't this one a little more involved than previous years?
Old Jan 22, 2007 | 08:41 AM
volfireman07's Avatar
volfireman07
I'm getting ready to change mine. Hopefully I will get to it this weekend. I will post if/when I get it done. Mine is a '74, so it shouldn't be much different.
In the mean time, if anyone has any helpful hints ...
Old Jan 22, 2007 | 08:50 AM
merlynr's Avatar
merlynr
Some of those glove boxes need to be kind of folded up like refolding a grocery bag to get it out thru the opening.
Old Jan 22, 2007 | 08:51 AM
1975Ford's Avatar
1975Ford
volfireman07, welcome to FTE, https://www.ford-trucks.com/guidelines.html
Here you go https://www.ford-trucks.com/forums/s...30&postcount=7
Old Jan 22, 2007 | 02:07 PM
Keepin It Real
1975Ford, thanks for all the info. I appreciate your willingness to share. It's this kind of participation that makes these forums such a great resource. The level of knowledge and experience found in these forums is truly impressive. I look forward to be able to help someone else with what little I know. But that would mean they know less than me....can't be many of those people around. Thanks again.
Aaron-71
13
Oct 31, 2011 10:16 PM
57 t-bird
Sep 21, 2011 12:50 PM
Riggstad
Jun 27, 2011 11:31 AM
dkk
1997 - 2003 F150
May 29, 2010 04:27 PM
firebug
Nov 5, 2008 07:10 PM
