estimated hp
Old Jan 25, 2007 | 07:25 AM
bigsnag's Avatar
bigsnag
I'd go full 3" with an X.
Old Jan 26, 2007 | 03:38 PM
James Campbell's Avatar
James Campbell
I've heard there will be noticeably more interior noise with 3 vs.2.5". Since I've no experience with a 460 with 3" in a Panel truck, I'm completely in the blind. I don't want it to be stealthy, however I will want to play stereo on the highway.....
Old Jan 26, 2007 | 07:23 PM
bigsnag's Avatar
bigsnag
I think the sound is more determined by the type of mufflers that you choose. An X pipe will also decrease the noise level. If you go with 3", an X pipe and then a pair of Flowmaster 70 series big block Delta Flows, the noise level will be fine. Here is a chart also to help determine size. Your setup needs full 3" to make your proper power.
Old Jan 26, 2007 | 07:26 PM
bigsnag's Avatar
bigsnag
Here's a link to the exact mufflers I personally would use. The sound great on a BBF.
Old Jan 27, 2007 | 02:40 PM
Brad Brown's Avatar
Brad Brown
BIGSNAG!
I was asking before if anyone had this kind of program. I was wondering if I could bother you to run my combination? I am really curious?? I would really apprieciate it. Only when you have time. Thanks!
545 C.I. Ford 385 .30 over with 4.5" stroke crank.
Scat Crank 520-9-460-6700-2200
pistons forged Probe 22 cc dished 9.7 compression
rods I beam 4340 ARP 7/16" cap screw 2-ICR6700-7/16
rod and main bearings rings Clevite 77
Stock D3VE heads with a big port job on the exhaust
Edelbrock Performer Intake 460 port and gasket matched to heads
Comp Cam Ford 429, 460 Xtreme 4x4 X4262H Cam & Kit PART # K34-235-4* comes with push rods, lifters, true roller set, springs, keepers, cam, intake .514 exhaust .524 / duration @ .006 262 and 270
/ lobe seperation 111
Crane roller rockers 1.73
Headers Hooker Hooker 6824HKR
Hooker motor mount kit Hooker 12677
3" dual exhaust.
Spark Plug wires 8 MM
Holley mechanical fuel pump Ford 429/460 110GPH Holley 12-460-11
Holley Street Advenger Carb 870 cfm manual choke Part #: 0-81870
Valve covers Ford Racing M6582-C460
Flywheel
ARP Bolt Kit for flywheel, front end and intake
Distributor Stock electronic
370 block oil pan, check clearance. 9 qrt
oil pump and pickup
I am going to be running this in my rooster truck in my gallery.
If there is anything else you need please just let me know. Thanks again!
Old Jan 27, 2007 | 04:24 PM
bigsnag's Avatar
bigsnag
Here's what I came up with on your combo Brad. IMHO, I think you should run the Performer RPM or Stealth intake. The regular Performer is NOT big enough for your engine. Also, I think you are seriously under-cammed. Keep in mind that the VAST majority of people over-cam their engine. I ran that exact cam in my last build on a 460. With that long stroke on your engine, that cam will seem like it belongs in a lawn mower. You need something at least in the 235/245 I/E range with .550 or so lift. Look at this graph, you are running out of cam by 5000 RPM's. You might as well spin it to 6000. You have the components otherwise and you won't be missing the low end with that stroker anyway. So, just my $0.02. Hope this helps.
Old Jan 27, 2007 | 04:35 PM
bigsnag's Avatar
bigsnag
Here is that same combo with the Comp cams listed here:
http://www.compcams.com/Technical/Se...umber=34-771-9
Now it IS a roller cam, but with that combo, it's screaming for a big cam. I know it's quite a bit more expensive than a hydraulic setup, but just look at this difference. That's about 75 ft. lbs. of torque across the board and almost 100 more hp at the peak. Heck it's still could take more cam, it's nosing over at about 5600 even with that cam.
Old Jan 27, 2007 | 08:08 PM
James Campbell
Hey Big, I was reviewing my posts and you were close with your guess of 106 on my cam's intake centerline...it is 107. I just took a second to look at the pics of your Black truck you changed the color on....nice! Rust would have been a better color than the original....Thanks again for all the info..you guys on here are in a league of your own...too bad the parts guys don't have all this knowledge.
Old Jan 27, 2007 | 10:52 PM
bigsnag's Avatar
bigsnag
Thanks for the compliments. Yeah, most of the guys that work at Autozone, Oreily's, Pep Boys, etc, are all morons. There are some that really know their stuff. If you find one, remember that place and never go anywhere else.
Let us all know how much power your truck ends up making.
Old Jan 28, 2007 | 08:36 PM
James Campbell
Will do, Will probably only do the chassis dyno....The power to the wheels is what matters. Anyone have an idea of the power loss through the tranny, and rearend?
I'm using a C6 and a 9"....heard they love to eat power.
Old Jan 28, 2007 | 08:40 PM
monsterbaby's Avatar
monsterbaby
It's very general but I use 25% loss whenever I do any figuring. Like I said it's pretty general but that will almost always put you into the ballpark.
Old Jan 30, 2007 | 12:14 AM
Brad Brown's Avatar
Brad Brown
Big Snag
Thanks for all the great info. The cam seems a bit small for sure. I was wondering if that larger size of cam would work well for putting through the bush at low idle. As this truck is my hunting truck and we go slow quite a bit, but I need to tow heavy loads too and really that is what I need the most. Is there a Hydralic cam that could maybe split the difference? Any ideas? I really apprieciate all the great help you have been. Thanks again!
Old Feb 1, 2007 | 02:40 PM
  #28
302s&460srocks's Avatar
302s&460srocks
maybe the Comp Xtreme Energy w/ 270/278 adv duration, it's somewhere between the two
jeremy5wilburn
27
Jul 7, 2016 09:28 PM
SCRebel
1997 - 2003 F150
Dec 28, 2013 09:56 PM
Boss50
Mar 17, 2013 09:51 PM
cws10190
Dec 18, 2012 11:38 PM
