How much boost will a stock turbo handle?
Rob, what Mike's referring to is making adjustments to the waste gate to limit boost to 28lbs. Your particular issue is different, since you're not making sufficient boost. As a place to start I'd suggest checking the up pipes for leaks. I'd also suggest posting your problem in the 99-03 7.3 section. Those folks will have you squared away in no time.
TennesseeMustangPerf
1999 to 2016 Super Duty
17
04-13-2010 12:44 PM
ernesteugene
12-02-2007 09:40 PM
