What is the point of a spray on liner right away?
#31
Side note, if you're using a bed rug or a plastic liner to cover damage to a bed before you sell it, what happens if the buyer removes the liner (as he should) before the sale? Also, if you develop anykind of rot in the bed before spraying in a bed liner, there is a CHANCE (don't jump on me) that it could spread underneath without proper prep work. Also, why would you invest almost $500 in a spray in liner just to sell the truck?
I have a Rhino, I move stone several times each summer I've had the truck and got the bed liner with this in mind. Also move sheetrock, plywood, sand, mulch, etc. Nothing goes underneath, nothing scratches through it, it's tacky as hell, and it should add resale value to the truck. In 2 years it's still as black as night (it's covered by a toneau almost constantly).
In the end, it's a matter of choice. I've heard good things about Bedrug. So-so things about plastic liners (they tend to warp after a while, but are cheaper and easy enough to replace)
#32
You don't have to put up with a fading bedliner anymore. LINE-X now has a product called Xtra, made by Dupont only for LINE-X. It resists fading, resists loss of gloss, extremely durable (contains a Kevlar micro pulp), increased scratch and stain resistance, comes in black or exact non-fading color matches.
Here's Xtra in black. All you have to do is wash it off, no conditioners needed:
#33
#34
#35
Originally Posted by Wr3ckin_Cr3w
i was thinking of getting a spray on for my bed, but i didnt know that the liners would fade over time. Instant, what brand of liner did you have
#36
#37
I looked at the bedrug today. It still is the same as a drop in as it will definately allow water to puddle up under it. I admit I liked it and probably will install one. However I would not even consider it without a cover. I just put on an undercover top this morning. Now that is sweet!
#38
InstantGrits,
I just went outside to look at my BedRug. Yes I suppose water could get in at the front of the bed. The sides of the BedRug are under the bed rail so it might be hard to get water from there.
The good thing about a BedRug is if you get water under it, it is easily removed, the bottom is zippered to the sides.
I have a Snug Lid F2 that is lined with the same material as the BedRug material which is kind if cool.
#39
Blockhead,
I can see it wouldnt be real easy to get water there, and also easy to clean it out if it did. I like the way it cant scratch the paint off the bed also, so no rust under it. Like you, I have a cover, and am leaning heavy to getting one. Who woulda thunk it..I have always been a big fan of spray in. Thanks for the response BH
#40
Originally Posted by InstantGrits
Blockhead,
#41
Hey, I thought prepping the box before spraying involved sanding off the paint in the box. Isn't that worse than getting it scratched?
I got a regular Ford factory drop-in bed liner for $180. It takes a beating with me hauling rock that gets dumped in by tractor (I bet ya wouldn't dare do that on your spray-in!), pallets of brick sliding in and out by forklift, and me poking it while shoveling landscape material. Zero damage to the sheet metal below. I do notice some paint wear under the bedliner where it rubs against the floor, but that would be sanded down if I were to ever get a spray-in anyways.
If my bedliner does ever get messed up, I'll just go get another one...I'll still be ahead compared to a $500 spray-in job... :-)
Yah, stuff slides around in the back, but my bed extender takes care of that :-)
dbossman
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
24
10-13-2012 11:50 PM
panthers20
12-13-2011 01:36 PM
Big Bad Apple
18
09-01-2005 11:50 PM
Sycostang67
05-05-2003 11:06 PM
