I'm going to put a ZF 5 speed in my '95 5.0 4x4 F150. I need a shifter yet. Is a 4x2 and a 4x4 ZF shifter the same? Is the clutch disc spline count and diameter the same from a M5OD to a ZF? While I have the ZF in the garage, are there any easy wear items to replace? Such as input bearing or output? I figure I'll replace some easy items if it's possible. On the transfer case. I have 154,000 on the truck. The transfer case has probably been engaged less than 1,000 miles over those 154,000. Are there any wear items to consider replacing while I have it apart for the swap? Here is a reference link that I've been reading for FYI. https://www.ford-trucks.com/forums/1...t=m5od+zf+swap
The Mazda trans could be had in the F250 as well as the F150. The ZF is a little more common in the F250 but most I have seen have the Mazda trans. What about a F350?
