my old F3 axle (timken) have any value?
Originally Posted by blueflat
irondragon, that looks like the same rear in my 53 250. was it 4.88? From what I've been told 67-70 250 rears with 8 bolt switches easiest.
The axle I have has 3.54 gears and a Power-Loc, locking (actual locker, not limited slip) differential.. hopefully traction won't be an issue I'm hoping that this fairly mild gear ratio will help me get up to highway speeds.
I've been trying to get ahold of Irondragon or anyone else that has changed out the rear axle on an f3. I have a '52 with the Timken on it. I have gotten in touch with a guy who has a few rear axles from a '72 f-250. I keep hearing it's a direct bolt-in. Is there anything that needs to be done for the driveshaft or will it just bolt in also? Any help and advice would be greatly appriciated.
The best thing that I have done so for for my 53 F-25 was to swap a 3.73 dana 60 in and get rid of the 4.86 timken. It made it a lot more fun to drive and will actually get down the road 60 - 65 mph and not sound like the little flathead wants to come apart.
The install is truly a bolt in, just drop out the timken and bolt in the dana 60. It took longer to redo the brakes than to install it under the truck. No change to the drive shaft length no change of the u-joints just bolt it up.
Have a great day.....
Bob G
Bob G
I'd say they have some value:
Technical How to build a cheap Traditional QUICKCHANGE!!! - THE H.A.M.B.
~Jason
~Jason
dpilot83
1999 to 2016 Super Duty
17
09-21-2014 10:03 PM
fladoodle
08-21-2014 09:46 AM
Packard V8
20
02-21-2014 07:41 PM
