1948 to 1950 Ford F1 Front Fender needed!!
I have two front fenders on my 50 ford i just removed today, the inside are still nicely painted black the outside is in good condition. Its got some rust on the bottom parts on one, its not bad and can easily be fixed. I dont want to overcharge so if you are interested in these fenders or fender please write back and let me know if you are interested.
I am looking for information on swapping out my Dana 41 to a Dana 44 in a 1950 Ford F-1.
The truck has the original 8BA Flathead and 3 speed transmission. The Dana 41 has a 3.92 ratio rear end. The truck has 15" wheels. At 2500 RPM. its going 50 MPH in high gear.I found out that a 1957 thru 1972 F100 rear was the right width and would work with a few problems.
I called around to many junk yards in my home state of Georgia and asked if they had a dropuot rear end for a 57 to 72 F100 and all answers were no except one. It happens to be in my home town of Peachtree City. They want $250.00. I asked what the ratio was and he said it was a 3.25. I am now unsure if the 3.25 will be too high given what some people have said. I did check my tires and they are 88" around or 28" across. I guess the 28" is the number I need to use. of course third is direct.
I would appreciate more feedback on the 3.25 ratio before I pull the trigger on the purchase. I did check on Dana 41's and no one has one either junkyard or specialty drive train house has a 3.72 gear for a Dana 41
That brings me to the other delima. I will ask the junkyard to save the spring shackle bolts and the emergency brake cables but I understand the shock perches are different. The are smaller on the Dana 41 but the quesion if I get the shock perches off the Dana 44 which is still in the truck will they work with my 1950 F1 truck? Also I have heard that the drive line on my truck will be one inch to short. If I get the drive line out of the donor truck will it work?
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
07-22-2016 10:02 AM
68murc
02-22-2016 09:01 PM
carid
08-14-2015 04:32 AM
