Engine codes???
Old Jan 14, 2007 | 04:11 PM
kodasdad4x4's Avatar
kodasdad4x4
Engine codes???
I have pulled the codes on my truck,they are 122- TPS circuit below mininum 0.6 volts.and 636-TOT sensor voltage out of self test range. The thing is I just put a replacement engine in it,I used all of the original sensors except the knock sensor(its new). There was no check engine light before,so I am stumped.Everything is plugged in and there is no extra plugs or parts. As for the trans. oil temp. I didn't think that my 1994 F150 4x4 with a 5.0 had one. I thought only diesel engines needed that sensor.any help would be greatly appreicated.
