Hard starting f-350
Hard starting f-350
I want to start off by saying I have read through the hard start common mod sticky and I dont see a post that answers my question. I live in Utah and it has been getting pretty cold at night.( 30' down to 0'). If I plug my truck in at night it will start okay, a little white smoke but if figured it has 150k on it so I wasnt worried. If I drive to work and leave it in the parking lot all day and I am lucky if it will start at all. Alot of times it almost kills my batteries from cranking. Batteries test fine. It seemed to be missing also. I switched out the glowplug relay and it didnt change so I figured it was glowplugs. I took it to a reputable diesle shop and they said the glowplugs tested fine. They came up with oil pressure. I went to quik lube and had all of my fluids replaced. Fixed the missing problem and it starts a little easier but not much. I assume when they check my glowplugs, they checked my wires also but you never know. What else could be the cause if it is not glowplugs or the relay? I get enough white smoke to fill the whole front yard and I am worried if i leave it somewhere for the day and it gets cold it will leave me stranded. thanks in advance.
I replaced the relay closer to the windshield so I am pretty sure it is the correct one. The batteries I had tested at a local Autozone, so however they test them there is what I did. I think they load test them dont they? They said the charge was a little weak but I didnt think they were to bad. Maybee I was wrong. Thanks guys for the response. I am going to an icefishing derby in a week or two and am afraid of leaving my truck all day in the cold.
Firefighter 1406
26
11-21-2015 09:50 PM
E350_traveller
26
03-01-2015 08:02 PM
86f250XLT-4x4
16
05-13-2014 09:09 PM
Arps 6.9
03-01-2014 08:20 AM
