which "modern" engine would you pick?
Old Jan 13, 2007 | 10:33 AM
seventyseven250's Avatar
seventyseven250
I know I'll get blasted for this from everyone who thinks trucks should be restored to stock or not at all, but here goes.
Which newer engine would you choose to put in a fat fender (pre 56) truck? Assume this would be a streeet truck, 2wd, and probably have some kind of modernization of the front suspension with MII, Dakota or ?? front end. I'm leaning toward the 300 I6 or the 351W engines. I'd guess a decently warmed over 460 would be overkill and fairly heavy to boot.
Since my old truck only exists in my mind right now, I'm just looking for ideas.
Old Jan 13, 2007 | 10:40 AM
mtflat's Avatar
mtflat
If you're determined to go with the MII you should be safe with a 300, 302 or 351W. Later Mustang II's had the 302 as a stock option.
I agree a 460 would be too much weight unless you're building something that will mostly just sit around looking pretty. My trucks work so that affects my opinion. I'm sure you'll get others.
Old Jan 13, 2007 | 11:02 AM
GreatNorthWoods's Avatar
GreatNorthWoods
The 300 would give you some decent gas mileage but not much power without putting a lot of money in it. A 302 or 351W would be a good all around engine with good performance. If you're already leaning toward the I6 or 351W that's what I'd go with...
Old Jan 13, 2007 | 11:31 AM
seventyseven250
I'm by no means determined to pick the MII front end. I've heard some people have used Areostar with good success. They are cheap and plentiful around here. My choice of engine is more likely to drive the choice of front end than the other way around.
Old Jan 13, 2007 | 12:57 PM
4tl8ford's Avatar
4tl8ford
I would use the New Flathead, 1948 - 1953. I like it much better than the older flatheads.
Old Jan 13, 2007 | 01:29 PM
Nuthin's Avatar
Nuthin
I've always said that once the engine in Old Horse can't be rebuilt any more, I was going to go with a nice little 289... that'd be my pick.
Old Jan 13, 2007 | 01:33 PM
galaxie641's Avatar
galaxie641
If money was no object I'd go with a DOHC 5.4L or a 4.6L if the 5.4L would be too big. I saw a '46 or so with a Cobra engine in it and it was very nicely done.
Old Jan 13, 2007 | 02:12 PM
Col Flashman's Avatar
Col Flashman
Built 300 I-6 w/ a C-4.
Old Jan 13, 2007 | 03:03 PM
packrat56's Avatar
packrat56
302 or 351 seems like a good fit and amount of weight and power.
Old Jan 13, 2007 | 03:56 PM
Randy Jack's Avatar
Randy Jack
I think the engine and tranny choice, along with everything else about it, depends on what the truck's purpose will be.
If it is going to be a daily driver (to/from work) and haul stuff with economy, the 300 I6 is an excellent choice. If you want an occassional driver with enough grunt to blow away the ricers, the 351W is the way to go. If you want a show truck for cruise nights and shows, put a high-dollar EFI, supercharged crate motor in it. etc., etc., etc...
I would say "it's your truck"...but you don't even have it yet.
Get the vision in your mind, make a plan, and go for it!!!
BTW, even though I have an MII IFS, and it was one reason I bought my truck, if I was to do another one, I would stay with the stock suspension. There will be plenty of other areas to spend your money on, believe me!!!
Old Jan 13, 2007 | 05:26 PM
4tl8ford's Avatar
4tl8ford
Oops
Until I read Randy's Post I didn't realize it was a Dream Truck.
In that case I'd opt for an Anti-Matter Scram Jet with Duel Turbo-Blaffers. It's the ONLY way to go.
Old Jan 13, 2007 | 05:31 PM
Randy Jack's Avatar
Randy Jack
Originally Posted by 4tl8ford
...In that case I'd opt for an Anti-Matter Scram Jet with Duel Turbo-Blaffers. It's the ONLY way to go.
That's the ticket!!!! Why didn't I think of that? That's so "New School".
You crack me up, Dick!
Old Jan 13, 2007 | 05:34 PM
Bdox's Avatar
Bdox
Get a new V-10 and build a truck around it!
Old Jan 13, 2007 | 05:53 PM
pcmenten's Avatar
pcmenten
I don't consider the 300, 302, 351 to be modern engines. The modular are the modern engines.
I'd go with a stroked, roller cam 351W or C and an AOD.
Old Jan 13, 2007 | 07:34 PM
Fomoko1's Avatar
Fomoko1
I like the 302/351 engines. Fairly lite and with plenty of performance equipment availble from mild to wild with stroker kits as well.
