Max MicroTuner for Ford 7.3L Diesel Trucks have a question.
Supertuner
I have a Supertuner and it works fine. I have no complaints with Horsepower, but I'm not addicted yet <grin>. I don't have guages yet so I normally only run the lowest setting. I have had not problems with codes or the like and as far as I know everything is fine. I do have the mufflers off mine and I had 2.5 inch duals from the Cat back (I'm not that crazy about the noise and this way seems quieter). I agree that if you want a lot of bang for your buck you might want the DP of another custom chip, but I'm fairly happy with mine.
John
2003 CC dually 4X4, K & N FIPK intake, Superchips Max Microtuner, 2.5" cat back duals w/o mufflers- soon to have guages and probably fuel mods.
John
on
Originally Posted by GoBigOrange
I have a Supertuner and it works fine. I have no complaints with Horsepower, but I'm not addicted yet <GRIN>. I don't have guages yet so I normally only run the lowest setting. I have had not problems with codes or the like and as far as I know everything is fine. I do have the mufflers off mine and I had 2.5 inch duals from the Cat back (I'm not that crazy about the noise and this way seems quieter). I agree that if you want a lot of bang for your buck you might want the DP of another custom chip, but I'm fairly happy with mine.
John
John
I ran an SCMT, sold it on ebay for nothing. Started running a DP chip, now I think the SCMT wasn't worth what I sold it for. I don't mean power. Even though the DP is obviously stronger. What I mean is the beast just sounds and runs better. I think the best thing to be done is borrow a plug in tuner, run a DP tune and convince yourself.
John
John
Ya got to loose that 2.5" dual system... Your exhaust back pressures are thru the roof! I would bet money your EGT's went UP after the addtition of that. really, I have seen it done on many trucks and it never works. Get yourself a 4" turbo back and ditch the cat.
reply to CSIPSD
CSIPSD,
I plan to get rid of the cat as soon as warranty is out. I'll let you know about the temps w/duals as soon as I get guages in. I may be wrong about the 2.5", they may be 3" because the look pretty big. I am not a big fan of the noise from the 4" or 5" but I'll switch if I have to. I actually did the mod on recommendation from my father in law who has a similar setup so I didn't do a lot of research on it before.
Thanks for the advice,
John
John
Originally Posted by Orezona
Order some gauges or at least a Pyrometer and do a search for DP Tuner or Diesel Innovations. You'll probably decide on one of the two.
CSIPSD,
John
John
