DP F5 is in
DP F5 is in
OK. You guys made me get one. Installed it today and it is definitly stronger than my Predator on 100hp. In fact the stock setting feels like my Predator.
Drilled my dash, and made a permanent home where I can see it all the time. Right below the shifter. Nice digital display, New cable too!
1. stock
2. high idle
3. 60tow
4. 80econ
5. 120 race
Left my Predator 100hp tune in the PCM which will only work if I unplug the chip. Kept my Transcommand. All is well!
Thanks Jody and Diane.
1. stock
2. high idle
3. 60tow
4. 80econ
5. 120 race
Originally Posted by Tenn01PSD350
Could this be because the predator tune is still there when in the stock tune positon? If so, that wouldn't really be a stock setting then would it?
Call Jody, he'll explain it.
0 position is also stock.
But you can't get to 0 unless you press both buttons, and then turn off your key. In that position, anyone driving it can't get to the other tunes unless you know how to work the display buttons. Good thing to prevent anyone else driving your truck from going too fast.
I'm not calling Jody. I asked you. As far as I know, the stock setting is just that, no tune, or what is in the PCM, or simpler yet, chip disable/bypass. If I have that wrong, let me know. Jody does not want to talk to me as I am not a customer. I would hate to think that I would have to pay for a "stock setting" which is already in my puter???? Now that I think about it, I may have done just that with my TS chip. Dammmit. If I did, that position ought to be a chip bypass one. And it should cost nothing.
Only way to get to the stock pcm tune is pull the chip. There is no switch to switch it off.
That is what I thought, but did not like. Why pay for a "stock tune"? BS if you ask me because it is there. I would think there should be a "Do nothing tune" where it is bypassed and that position should cost $0. JMO.
Of the 3, hi-idle only cost $25.00. The other 2 are $45.00 each. So stock is free for sure, and the 80econ also. I added the 60tow, hi-idle, and 120 race as xtras.
Hello,
How does the chip work/feel with your transcommand. Does jody program it to work with the transcommand. Does it shift any different now with the F5 or the same as it was. I have a transcommand on my truck, and was thinking about getting a DP chip. I was just wondering about how it worked from someone that had it. Hope this makes sense.
Thanks
Thanks
Originally Posted by 670johndeere
Hello,
Thanks
Thanks
There is a pigtail connecter you get with the transcommand if you want to go back to stock. Just unplug the transcommand at the box, and put that connecter in and it's back to stock..
You have a Transgo shift kit with the transcommand. Is the shifting hard?
'Jody does not want to talk to me as I am not a customer'
You don't know that. Maybe you're right, maybe you aren't. If people are passionate about what they do, they will often dispense free advice because they like to. I've probably answered a million building/remodel questions for people whose homes i did not build. I enjoy it. Maybe they'll remember that and be a customer one day. You'll never know if you don't ask
