Quick Question-Kingpin Bushing alignment
Old Jan 11, 2007 | 04:12 PM
microb's Avatar
microb
I know the triangle hole has to line up with the grease fitting hole in the spindle, but does it matter which way the triangle points?? Thanks,
Mike
Old Jan 11, 2007 | 05:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If I understand your question, it sounds like you are asking if there is a "top" and "bottom" to the bushings? I've done this job and I just don't remember for sure, but it seems to me the grease fitting is not in the center (top to bottom) of the bushings. Just hold them next to the spindle and see where the hole falls relative to the grease fitting.
Or have I misunderstood the question? What triangles are you referring to; are the holes in your bushings triangles? I've never seen that.
Old Jan 11, 2007 | 05:25 PM
microb's Avatar
microb
Yes the hole in the bushing is a triangle shape. The grease "tracks" on the inside of the bushing are not symmetrical vertically, so I dont know if they are supposed to have a certain top and bottom. Unfortunatly for me, the grease hole, or triangle rather is actually about dead center on the spindle bore. I'm about to take a wild but somewhat educated guess and put them in, but I dont want to do it wrong.
Mike
Old Jan 11, 2007 | 06:33 PM
microb's Avatar
microb
Smile
Ok I drove the bushings in how I believe is the correct way. At least the grease ports line up. That FOMOCO reamer I got on ebay works like a dream, the kingpin slides in beautifully, not tight, and no wobble. Right now I'm loving life. =)
Mike
Old Jan 11, 2007 | 06:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You won't believe the difference it makes in steering effort and the truck keeping a straight line going down the road! Good job!
PS -- Don't forget to grease it!!
Old Jan 11, 2007 | 06:49 PM
microb's Avatar
microb
Once I get new springs and shocks, I will reassemble everything and take it for a ride. Cant wait to feel the improvement, and the brakes will actually stop the truck now!
Mike
jonf
Aug 27, 2012 03:46 PM
str8sixman
Jun 22, 2012 09:00 PM
460
1983 - 2012 Ranger & B-Series
Mar 16, 2009 08:46 PM
NuDog
Jan 14, 2004 10:45 AM
a63unibody
Feb 19, 2003 04:55 PM
