Inherited 94 F350 Turbo
I now own a 94 F350 Turbo diesel that has sat for 2 years, and came to me saying that it came from the mechanic, who wasn't able to get it started, but narrowed down the problem to wiring. Now, I am a novice mechanic, so I was wondering if there are any resources for all related wiring diagrams, etc?? I am an engineer by trade, so I thought I could do some testing to try to eliminate any obvious problems. Also, if anyone has any resources that would list some rule of thumb tips/tricks for the 94 Turbo Diesel, I would appreciate any help. WOuld you recommend buying a manual for the engine and truck??
Thanks much...
Thanks much...
Welcome. Don't buy a manual just yet. Spend the next couple of nights checking out this site and Steve Baz's stuff. Buy a CPS (camchaft positioning sensor) off e-bay immediately for around $40-$50. Even if you don't need it today, the day will come when you do need it. Change your oil and filter making sure that your HPOP reservoir is filled up. Change fuel filter and make sure canister is filled up before putting top back on. Clean all connections and charge batteries really good with a 3-10 amp trickle charge for two days. Check all your fuses, paying close attention to #22 under your hood. Try to locate someone else who has a PSD and see if he has a tuner that can read the codes from your truck's computer. Do this before you unhook the batteries. If you can't or if you already unhooked the batteries, no big deal. Have fun with it. Before you know it the truck will be running and then you'll be modifying it for more power and better performance.
Originally Posted by DAVID'S97F250HD
WHAT YOU JUST GOT WOULD BE the most fun of all jobs, you recieve ths truck, the hitch is you have to get it going, the day you get it going will be one of the best days ever.
Is it for sure a powerstroke though???
Originally Posted by foster0004
I checked and found the oil fill cap is on the valve cover, so looks like I have a DI Turbo model. I have a Haynes diesel manual that covers this engine. I will be posting my progress here as I work on it. Thanks for your help so far...
