New York Chapter Join Chapter, Leader: tiny1
Looking for stock 17" SD wheels for my 99 F250
Old 03-01-2007, 10:44 PM
Jack_99V10's Avatar
Jack_99V10
Jack_99V10 is offline
I need 17" wheels for the tires I'm looking at. Stock would be nice, and should be relatively cheap. If you or someone you know has a stock set sitting around in or near WNY please let me know ASAP. Tax returns were good to me after I itemized, and the house came into play
Think I'm going to go up 6" with a ProComp or Skyjacker lift... and then some 37x12.5x17 Interco SSRs.
716-901-1081
Thanks,
Jack
Old 03-04-2007, 10:09 AM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Jack - remember that you want wheels that go to a 1999 to 2004 SD and not 2005 and up. The 2005 and up wheels have different backspacing that from what I understand will cause rubbing. Also, stay away from a Pro Comp lift on the SD. Everyone that has run one has regretted it. They run very stiff.
Old 03-04-2007, 12:13 PM
Jack_99V10's Avatar
Jack_99V10
Thanks for the heads up... I think Skyjacker is going to be the way to go.
Old 03-04-2007, 12:58 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Check out Skyjacker's Softride system if you do go that route. You might also want to look at SuperLift systems that come with Bilstein shocks and Donahoe Racing which come with Deaver springs. Donahoe will be the most expensive, but probably give you the best ride. Skyjacker and SuperLift make good systems and Full Traction has come out with some nice kits too.
Now I got you thinking!!!
Old 03-07-2007, 08:55 PM
Jack_99V10's Avatar
Jack_99V10
Bought an 8" BDS full spring kit.
Also bought these:
Old 03-08-2007, 02:28 PM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
FWIW, Donahoe Racing now has their own proprietary leaf springs and no longer use Deavers.
Old 03-08-2007, 07:36 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Jack - so what size wheels did you go with? 18x8? That should be sweet when you get it done. Going to have it done in time for the Letchworth G2G???
Dan - thanks for the clarification. I didn't realize that DR did that. Nice to see you here in the NY Chapter. Feel free to stop in any time!!
Old 03-09-2007, 06:12 PM
Jack_99V10's Avatar
Jack_99V10
17x9.
Pix are deceiving.
Also got these...
37x12.5x17 SSR
Old 03-09-2007, 08:46 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Sweet!!!
Old 03-10-2007, 12:56 PM
Jack_99V10's Avatar
Jack_99V10
got them mounted today... but couldn't balance them. The snap on balancer my buddy had wouldn't accept the huge hub hole in the wheels... so we have to think of a way for that to work.
Old 03-10-2007, 02:22 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Jack - make sure you get those balanced right. Those 37's will have a lot of rotational mass and will give the truck a bad vibration if you don't.
Old 03-10-2007, 09:23 PM
Jack_99V10's Avatar
Jack_99V10
I'd say the wheel/tire combo is like 75lbs.. maybe more.
I left the set at the shop, he will figure something out and get them balanced. The lift is going in Wednesday... I can't wait.
Old 03-11-2007, 05:51 PM
Jack_99V10's Avatar
Jack_99V10
Should be balanced tomorrow morning... I hope.
Jack_99V10
New York Chapter
03-19-2007 09:55 PM
davidsheets
1999 to 2016 Super Duty
08-03-2006 04:39 PM
SkylinePCG
1997 - 2003 F150
02-11-2006 05:10 PM
SkylinePCG
02-08-2006 09:21 PM
outdoorsmen
2004 - 2008 F150
10-02-2004 11:18 AM
Quick Reply: Looking for stock 17" SD wheels for my 99 F250
