460 in 59 F100
460 in 59 F100
Viking,
I put a 302/C6 into my 60 F100. I used TransDapt motor mounts but I wouldn't use them now that I know what they are. If you have a welder or access to one I would make my own. You can get just the rubber pieces from TD which is what I would do. As far as the installation, I centered my motor between the frame rails. For the front to back distance I just used what looked good, ie: what gave me the space I needed for the trany dip stick and the kick down rod. This left just 4" between the radiator and the water pump so I'm going to use electric fans. Also the motor set lower so the fan wouldn't have been centered on the radiator anyway.I'm also using a B&M tranny cooler because my truck was a standard. I also had to cut the front cross piece for clearance of the crank pulley. I have a few pictures of the engine in place. If you want send me your Email and I'll send them to you.
Bob Wood
BOBWOOD536(No Email Addresses In Posts!)
60 F100
302/C6
Bob Wood
60 F100
302/C6
460 in 59 F100
i'm taking a 351 clev with an fmx out sun, and putting in a 460 -c-6 , in my 57, the engine will sit in the same place with the lincoln ratiator, i already have the motor mounts made for the 351 and they should fit, but i am having trouble finding headers. so if any one knows where i can find them??
460 in 59 F100
Good luck on your swap. I'll be real interested to hear about your fan/radiator and engine/firewall clearance. Please keep us posted. As far as headers, I was thinking of some of the block huggers that they make for the 460 in street rods. (Sanderson etc.) What kind of Lincoln radiator are you using?
460 in 59 F100
found a 288 cam today with a 515 lift for $50 new,
ordered the lifters also , and i got a double roller timing chain. it looks like the sanderson headers will fit ,but they are a little costley , about $250.00. still can't get the grill out, bolts behind haed lites , but they WILL come out one way or the other
460 in 59 F100
If you are going to switch to disk brakes, try ECI components. They sell the complete kit for about $350. That is cheaper than you can rebuilt those old 40 year old units. I just got the kit for my '63 and if you'd like some more information, e-mail me at skip4274@flash.net
Skip4274
4everFord
By the way, I disagree with the trans-adapt motor mount posts. I have put three motors in trucks with them and had great success. The only problem is dropping the pan if you WELD them in. If you bolt them in, there isn't much problem. Besides, it stiffens the chassis.
Skip
Skip4274
4everFord
Skip
blubayouclassiccars
19
11-17-2010 07:27 AM
ddunham
01-03-2003 06:18 AM
tmessenger
11-27-2001 10:42 AM
