7.3L oil leak?? look here
#76
#77
#79
OK, just received another email from him and I hope he doesn't mind me posted the email up for you guys but here ya go..............
From me:
The guys over at FTE posted up your saver kit and we’re
wondering how much you charge for the kit. The kit looks real nice and the
results look extremely promising. I think some of us are thinking of maybe
using the kit before we ever have any problems. What are your thoughts on using
the kit before a problem arises and how much is the kit?
From Mr. Frattasio:
thanks for the thread Pat,the price is 235.00.i charge 650.00 to install it total price, which includes the kit, oil and filter.using the kit before you rot through is the absolute best way to use this for two reasons, it makes the prep and install a breeze when you dont have to deal with dripping oil,and you will never have a rot problem in the sump area.you could also not drain your oil before install. ive done so many oil pans in these things it made me sick,family men spending large dollars on this foolish rot problem that ford new about for 10 years and never changed the corrosion protection.i finally lost it when in a moment of weakness i decided to do a friend a favor and clean & paint his ok looking pan before he had a problem,thats when i scraped a blister off his pan it started to leak on my lift,i would have given about anything to has this kit then. thanks again for the interest,looking forward to dealing with you guys.
From me:
From Mr. Frattasio:
#80
Definitely worth a try even at the price of 235 given the alternative. I am keeping a close eye on my pan. I do not have any surface rust at the moment but I think where you live and the climate in your area is key. Strange thing is that my rear diff cover is a rust bucket! Really bad. So I bought an aluminum 08' rear diff cover a couple weeks ago. Will be installing it in a few days. Too bad the oil pan can't be fixed that easy.
#84
Guzzle at Dieselorings.com Best prices and unbeatable customer service.
#85
#86
#87
1997 f350 oil leak
I am not sure if it's my HPOP. My leak is appearing from above my starter. It only does it after it is running or idling and stops 15-20 min after it is turned off. The ford dealer told me about a year ago that my oil cooler needed replacing so I did that and now I have this new leak.PLEASE HELP. I want to fix it so my husband doesn't have to. I am mechanically inclined.
#88
Still from the rear? It will come from that area, but your valley should be full as well. Sop up the oil with towels or rags and see which end of the valley fills up first. There are horizontal channels in the valley pan that will collect oil and they are VERY helpful in figuring out which end of the pan it's coming from. If it fills from the front, then it's an HPOP O-ring(s) and if it fills from the rear, it's your turbo pedestal. Mine filled from the front and took only five minutes to fill up the first lobe. I bought an O-ring kit from Ford, but you can get a complete kit from Clay (actually from guzzle, but Clay sells 'em and I love dealing with Clay!). Here's the link for both ends:
The HPOP (don't add the HPOP engine gasket, but DO add the serviceable plug):
Riffraff Diesel: HPOP o-ring kit w/ 7 o-rings
Here's for the turbo pedestal:
Riffraff Diesel: Turbo / Pedestal O-rings
#89
Leaking plug on the HPOP
02 7.3. The plug above the snap ring on my HPOP is leaking when I tried to find a oring for it I went ahead and stopped by a diesel shop they told me that they could never get that plug to quit leakiing. Well a new pump that he sugessted is 800$ from ford. Any ideas yall. Thanks for the feed back
#90
Replacement O-rings for Ford Diesel Engines
Bill
