Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Power chips
Old 12-02-2006, 09:16 PM
spider1472's Avatar
spider1472
spider1472 is offline
Power chips
Where would be a good place to get a chip for my 02 HD. As far as I know all that has been done is a lower pullie that I had installed. I have been in SWA (South west Asia) afghanistain since I bought the truck used and had not had much chance to see what the previous owner has had done to the truck.
Old 12-03-2006, 07:22 AM
harley f150's Avatar
harley f150
harley f150 is offline
With increased boost, it would be a good idea to have a custom chip made. Find a tuner that can get your truck on the dyno and get the fuel and timing curves right so you don't blow the engine.
Old 12-03-2006, 12:55 PM
LEVEL10's Avatar
LEVEL10
LEVEL10 is offline
the best all around case is finding a custom tuner near your home.
go into www.sctflash.com type in your zip code and search for say 50 miles around your home area. contact them for a custom tuned excalibrator 2 done to your needs.
i think you will find this works the best as most of the other tuner companies tune for where their shop is and load a best all around tune. which say you live in CO. at 5000 feet it will not work as well as it did a sea level.
good luck and thank you for your service to this wonderfull country.
captchas
LEVEL10 power phone tech.
Old 12-11-2006, 03:06 AM
spider1472's Avatar
spider1472
Talking Thanks
Hay thanks for the help
Old 12-11-2006, 07:12 AM
wendell borror's Avatar
wendell borror
wendell borror is offline
You can also talk to Bob at jusnesmodified, he sells the bama programer that alot of us use. Bob is a site sponser here. Or you can get a hold of Doug directly at www.bama chips.com. Doug is a ford guru and only does ford programs. All of us who use bama will swear by it, I think he can help you, he also does custom tunes.
Old 12-14-2006, 07:05 AM
spider1472's Avatar
spider1472
well I got a programer the other day when they put on the pullie Diablo Sport (Predator Tunable Performance Programmer) any one know about this brand is it any good and cant it take care of every thing I will need?
Old 12-14-2006, 10:50 PM
ckirwan514's Avatar
ckirwan514
ckirwan514 is offline
The Diablo Sport Predator is a good unit . the SCT/Flash programer is an upgrade as it has more features than the Diablo Sport. (I use the Diablo on my 02 lightning) my tuner is a SCT dealer but has no problems tuning my truck on his dyno and using the Diablo. hope this helps. Remember it is more important to dynatune your HD than to just bolt on mod's. do the mod's then tune.
Old 01-16-2007, 03:56 AM
spider1472's Avatar
spider1472
Finally got to drive the truck after every thing was done and it is quick. once I get a chance to get the dyno sheet scaned I will put it here the only other thing I can tell that was done is the cold air intake what kind of times should I be looking at from the stock HD?
kaptainstingray
05-23-2013 12:17 PM
redford
1999 to 2016 Super Duty
75
09-27-2008 06:09 AM
BigF350
International Region
25
10-21-2006 07:04 PM
poolpro51
17
01-28-2005 12:16 AM
Quick Reply: Power chips
