1978 - 1996 Big Bronco
Bassani Y Pipe Install
Old Jan 5, 2007 | 06:40 PM
arib's Avatar
arib
I ordered a Bassani y pipe for my 89 302 and I can't wait to get it. In the meantime I was wondering what kind of wrench is the best to use to get the old y pipe off from the stock manifolds. The bolts are rusty and I already started spraying them with penetrating oil, but the passenger side looks next to impossible to reach. Any ideas?
Old Jan 6, 2007 | 05:34 AM
s1120's Avatar
s1120
Was not bad getting the old one off of my 95. I did need to use a wabble, and some extentions on the pas side rear bolt. I used a impact. I snapped the studs, but then agean I was not reusing the manafolds.
Old Jan 6, 2007 | 06:08 AM
moemeadors's Avatar
moemeadors
I just did a header swap and wound up cutting a couple studs, if you are reusing the manifolds I am afraid you won't be too happy when you are done. I picked up a set of headman shorties on e-bay for $110...you might want to consider doing a header swap too. The manifolds are junk and tend to crack anyway. It is worth the peace of mind. I know you just dumped 250+ on the y-pipe, but there just isn't any for sure way.
Moe
87 & 89 302 bronco's
89 351 f250
Old Jan 6, 2007 | 06:52 AM
Big Daddy J's Avatar
Big Daddy J
I've got an 87 and I coated the bolts with PB Blaster and they actually came right off after they broke loose. I started spraying all the bolts 3 days before I did the exhaust work.
Old Jan 6, 2007 | 07:33 AM
moemeadors's Avatar
moemeadors
Like I said, it is a crap shoot...I wish you the best Paul.
Moe
Old Jan 6, 2007 | 12:28 PM
arib's Avatar
arib
Thanks for the input guys. Moe, I was thinking of getting the hedman shorties as well but haven't been able to find them for that price. Would it be easier to do headers and y pipe all at once so if need be I could cut the old manifold studs?
Ari
Old Jan 6, 2007 | 01:22 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well, its really easier to just break the manifold studs loose by trying to uncrew them.
If they break then whatever.
I found it more of a peace of mind when I went with the bassani headers and y-pipe.
Old Jan 6, 2007 | 01:53 PM
arib's Avatar
arib
I'll try to get the nuts off with an impact wrench, and if I break a stud then I'll order the bassani headers. If not, I will wait and see how the y pipe runs with the stock manifolds.
Old Jan 6, 2007 | 05:30 PM
dhepler's Avatar
dhepler
I have the Ford ss headers and the Borla cat back , was real happy but had to have the Basani y pipe, once installed wish I had put the money somewhere else. No improvement, not impressed.
Old Jan 6, 2007 | 10:15 PM
JetBlackBronco's Avatar
JetBlackBronco
im considering swapping the factory headers and dual exhaust from my 93 Lightning to my bronco, cuz im goin with long tubes, and true duals on the L. i hope there will be some improvement.....
Old Jan 7, 2007 | 06:03 AM
moemeadors's Avatar
moemeadors
The manifold bolts to the head come off easy...its the ones to the Y pipe that kicked my bootie...
chevyassasin
Mar 16, 2012 03:01 PM
Edgethis
Jun 18, 2011 03:18 AM
arib
13
Feb 1, 2007 08:28 AM
gjordan456
16
Apr 6, 2005 02:57 PM
geezer95
18
Feb 19, 2005 08:34 PM
