I have a problem with my 04 screw. Whenever the temperature dips close to or below freezing my doors seem to be glued shut. I have to pull pretty hard on the handle to get the door open. It could be caused by moisture in the door jam and along the seals. I do live in vancouver and it does rain alot. Since the truck is only a couple years old, why are the seals so sticky like that? Is there a lubricant i should use on the door seals to prevent this from happening?
Just got an '04 Scab this past summer. We're just starting to get the really cold weather (it's been a weak winter here in Connecticut) and that's happened to me twice this week. The temp has been around 10, but no rain or ice so I knew it was something else. I'll give the silicone spray a shot.
