Griding and Clunking
Old Jan 3, 2007 | 06:14 PM
FordF350Baby's Avatar
FordF350Baby
I want to know what you guys think the problem is. I have a 1995 F350, 4x4 Auto. I recently got the yoke replaced from a service shop because the truck had vibration problems, when I got it back, I noticed a loud grinding noise when I deaccelerated. I had never heard this noise before. So, I brough the truck back to them and asked them to fix it because I had never heard the problem until they put the yoke in. The truck also clunked into first gear while accelerating, another new noise that hadnt been there. I got the call back few hours later, and they said they couldnt figure out what the noise was unless they took apart the rear end. I was pretty outraged because a small problem has turned into big thing. So I took the truck out of there, and brought it to the dealer where I feel a tad more comfortable handing it over to experts. What can I expect to hear when the Dealer calls back guys? What would be making this grinding and clunking noise that wasnt there before but now is after the new yoke got installed. The truck runs great while under acceleration, I did a 20 mile trip on the highway today going 85mph non stop, and it road very smooth, but as soon as i needed to slow down, the grinding noise was very aggressive. The shop that had fixed it claims its making the noise now because everything is tight, which makes no sense to me, and I feel jipped. What you think?
Old Jan 4, 2007 | 11:46 PM
385seriesHemi's Avatar
385seriesHemi
I would have to say the grinding could be the Drive pinion bearing being too tight or bad. The case bearings could be going bad too. How many miles on it? and how long has it been since you changed fluid?
Noise will be made if its too tight or too loose on the drive pinion bearing.
Old Jan 5, 2007 | 07:07 AM
stuart1's Avatar
stuart1
Find out what is wrong then voice an opinion.
