New Jersey Chapter Join Chapter Leader: sddesigns
Need a Tune-up, or Fuel Injector, or ? ? ?
Old 06-20-2006, 08:06 PM
GeoDaddy's Avatar
GeoDaddy
GeoDaddy is offline
My Big Black F250, Full Cab, Longbed... I
Have reached a fuzzy point in our relationship. In the last couple of days, it feels kinda sluggish starting up, idling high, sounds like some straining of some mechanical function... until it falls into the next gear.
Only variable that I can think of is the A/C which I am using for the 1st time on this 1999 truck with 230,000 miles.
It kinda feels like it did last March - just before the Water Pump blew.
The only other feeling that I can recall was a couple of years ago when the fellow I bought it from (and I) were driving across country and two Fuel Injectors had to be replaced... but I was too unfamilar with "trucks" to be able to notice any sound... but my friends did.
Sounds like a visit to the Ford Dealership for another skinning???
Thanx
g
Old 06-21-2006, 09:55 AM
frederic's Avatar
frederic
frederic is offline
What year? What engine? What code number on the driver's door jam?
The first thing I would do, instead of guessing or taking it to the dealership for a prompt raping, is to borrow a code scanner and pull out the codes out of the EEC. Generally when things go awry, the computer in your truck knows about it, and tries to compensate. It can compensate for a while, then you'll start to feel/see/observe symptoms.
If you don't have access to a code scanner, and have a check engine light (or a volt meter, or a 12V test light), you can wire it up like so at the top of this page, then pull codes doing a Key-on, key-off test.
http://frederic.midimonkey.com/f350-eec.html
Old 06-21-2006, 07:22 PM
GeoDaddy's Avatar
GeoDaddy
GeoDaddy is offline
Hmmm... that's some advice. Let me digest it. It's '99 Ford F250 with the V8 Power Stroke. I'll have to check the bar code on the driver's side door.
No warning lights are on.
I don't have a scanner. Are these available/expensive?
I'll let you know when I get a chance to check out this bar code thingy.
Thanx!
g
Old 03-03-2007, 01:39 PM
matts156's Avatar
matts156
matts156 is offline
The PowerStrokes have a camshaft position sensor that can really screw with the engine's running quality when they start to go south.
Old 03-03-2007, 02:14 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
yup, what matts said. sounds like a cam position sensor. where are you at?? if you ain't to far, i have a scanner and Will read it for ya.
if you join the jersey chapter first.
pohoda
04-02-2015 03:10 PM
abowman
84
04-01-2015 05:03 PM
KimbroZz
10-24-2014 05:17 AM
Mcfarlane11
18
01-07-2014 07:29 PM
chunger
1997-2006 Expedition & Navigator
38
11-06-2011 03:23 PM
Quick Reply: Need a Tune-up, or Fuel Injector, or ? ? ?
