2005 Ford F-350 radio wiring
Welcome to FTE!
<TABLE borderColor=#d3d3d3 cellSpacing=0 cellPadding=0 bgColor=#ffffff border=1><TBODY><TR align=middle height=18><TD>Radio 12v
</TD><TD>lt. green/purple
</TD><TD align=middle width=135>+
</TD><TD>radio harness
</TD><TD align=middle>
</TD></TR><TR align=middle height=18><TD>Radio Ground</TD><TD>black and black/lt. green </TD><TD align=middle width=135>- </TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>Radio Ignition</TD><TD>pink </TD><TD align=middle width=135>+ </TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>Radio Illumination</TD><TD>lt. blue/red (dimmer) </TD><TD align=middle width=135>+ </TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>Factory Amp Turn-on</TD><TD>N/A </TD><TD align=middle width=135></TD><TD></TD><TD align=middle></TD></TR><TR align=middle height=18><TD>Power Antenna</TD><TD>N/A </TD><TD align=middle width=135></TD><TD></TD><TD align=middle></TD></TR><TR align=middle height=18><TD>LF Speaker +/-</TD><TD>orange/lt. grn - lt. blue/wht </TD><TD align=middle width=135>+,-</TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>RF Speaker +/-</TD><TD>white/lt. grn - dk. green/org </TD><TD align=middle width=135>+,-</TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>LR Speaker +/-</TD><TD>gray/lt. blue - tan/yellow </TD><TD align=middle width=135>+,-</TD><TD>radio harness </TD><TD align=middle></TD></TR><TR align=middle height=18><TD>RR Speaker +/-</TD><TD>orange/red - brown/pink </TD><TD align=middle width=135>+,-</TD><TD>radio harness</TD></TR></TBODY></TABLE>
Welcome to FTE!
<TABLE borderColor=#d3d3d3 cellSpacing=0 cellPadding=0 bg*************** border=1><TBODY><TR align=middle height=18><TD>Radio 12v
Old topic I know but Kind of releavent to my questions, err, at least one of them, The other is a Door lock question but still in wiring.
1st - What all wores ar behind the radio of a 2005 F350 KingRanch with the 6-disk and wheel controls? is the wheel control just one wire or is it a whole seperate plug, I already have one of those metra wireharnesses all set up for the power, dimmer, and 4 speakers, from another truck (06) but the old one didn't have the steering wheel buttons.
The one that is kind of off-topic is, If I was to install an aftermarket alarm is there ANY way I'd be able to hook up to the stock Keyless thingy so that I can still use the door keypad but not have the interior buttons back feed into the alarm, Maybe a wire I just have to diode?
Thanks in Advance,
Eugene
Thanks in Advance,
Eugene
Your truck has a databus, basically is like computer network with the different components in the truck talking on one line. The databus should convey the steering wheel controls. The question is what kind protocols are used and how do you make the new radio accept the other devices on the network?
For the alarm, if you just tie in lock/unlock wires, it will not arm the alarm when you lock using the door controls. All of the models I've played with will only arm when you use the alarm's keyfob to lock/arm the system.
