What did I just break?
To the left of the fuel filter, there are 2 cylindrical black objects with 4 electrical connections on the top of them. I just busted a post off of the back one tightening the nut.<O</O
1) What is it?
2) Can I get it at AutoZone or do I have to wait for the parts dept to open at ford?<O</O
<O</O
No fun today!
Dan<O</O
1) What is it?
<O</O
No fun today!
Dan<O</O
By back one if you mean the one closest to the windshield it is the Glow Plug Relay. The one closest to the radiator is the IAH.
GP-110 is the one for our trucks but cost more the 109 is a sub but read this before deciding to use it.
https://www.ford-trucks.com/forums/s...71&postcount=8
GP-110 is the one for our trucks but cost more the 109 is a sub but raed this before deciding to use it.
OK...went to AutoZone and they said it was a starter solenoid. He pulled it out of the box and it was almost an exact match. I finished changing my HPOP O-Rings and replaced the broken part with the starter solenoid. The truck started without issue.
I now pull my front tires to blow out around the anti-lock break sensors and fix a broken vacuum line going into the drivers side hub. Now that's done, I go back to start the truck and the batteries are dead!
What the heck happened???????
EDIT: They gave me a Duralast F491.
The starter Solenoid is attached to the inner fender behind the pass side battery right next to the vacumn pump. Not only did he tell you wrong he gave you a solenoid that energizes differently and your glow plugs have been On since you hooked it up.
Well..as soon as the batteries died, I pulled the cable off the batteries and started slow charging the drivers side one. I also took the starter solenoid off and took it back. Autozone had nothing else and NAPA was closed so I went to Advanced. For my truck they only listed this $275 monsterous steel thing that definately was not it. The only thing they had close was a GP Sorenson MR99 Solenoid which they said fits the older trucks. I bought it because it looks very similar to the description of the GP-109 that was refered to earlier. What to do? I have to move the truck so I figure I install, move and then pull the battery cable again until tomorrow.
The new solenoid has an "S" side and an "I" side for the two smaller posts...anyone know how that would relate to my truck?
BTW...I did initially tell the guy in AutoZone that I needed a Glow Plug Relay and even brough in the part...he still sold me the starter solenoid...last time I trust them...
Originally Posted by GREGROB
GOD THOSE GUYS ARE STUPID SOMETIMES.
I'll tell you this, they would be giving me a new set of batteries and a new set of glow plugs AND pay for them to be installed.
I would raise ABSOLUTE HELL with that store.
If they didn't give ME all of the above, I would be giving them that relay thru their WINDOW, I do believe... and I'm not given to violence!
