F150 transmission crossmember removal
I was fixing to change the transmission oil and filter for the first time today.When I got under the truck to unbolt the crossmember thats holding the transmissions weight, i saw two bolts at the top of each side of the beam bolted to the top of the frame.And two bolts on each side holding on to the radius arm anchors,and two bolts are on the trans support itself.The bolts are not the problem though, what I need to know is how do you move it back with the transfer case in the way,and how do you move it forward with the headers in the way.There has to be some tricks to the romoval of this crossmember,anybodybody know one.
tigerfan79
06-03-2017 08:17 PM
JeffStrachan
09-05-2016 12:06 AM
F250Rob
01-05-2011 04:30 PM
Doc
10-27-2010 07:48 PM
cantedvalveFord
10-07-2007 10:19 AM
150, 1973, 1979, 79, bolts, crossmeber, crossmember, f150, ford, modification, remmoval, support, trans, transmission, truck
