Oil leak from oil drain tube?
Sounds like the fuel bowl drain tube, there have been numerous leaks lately due to the orings that seal the valve. its on the back of the fuel filter housing - cycle the yeloow handle a couple of times and see if it will stop. Sometimes a little grit will get stuck in the valve but if that doesnt fix it you will probably need the orings.
http://www.puredieselpower.com/catal...ngs-p-103.html
toward the front or back of the motor?
On the passenger side toward the front is the Fuel drain tube closest to the motor and just outboard of it is the Exhaust backpressure sensor tube. They tend to get clogged with soot and if it cracks or breaks and get moisture in it it could look like oil.
