gas tank siphon tube question
drained the tank in my '64 F100 yesterday to get rid of old fuel. also installed a new sending unit while in there. ran great until I took it out on the road, then started stumbling and eventually died. isolated problem to fuel flow from the tank, as in, there is almost none. I can blow air down the tube, but seems restricted. question: does the siphon tube have any kind of filter or screen on the end of it that might be clogged? or is it just a stright piece of pipe? TIA - Paul
poboy, Have you removed the tank from the truck. I suggest that since you have rodded the line, you pull the tank and rinse it with new gas and see if you can pour any matter out of the filler neck. If it stopped up that fast there must be something in there that needs to be gotten out.
Once it's rinsed well, you shouldn't have any more problems.
good luck
John
good luck
John
Hehe! Join the club!
To clean out a tank a lot of people use a bunch of old screws and nuts mixed with water and detergent. Agitate the tank, turn it over and over, -anything to let the assorted hardware scour out the tank. Do that a couple times, empty the junk out, flush with water and allow to dry. Flush with alcohol and allow to dry. Then get some gas tank coating sold as kits in auto supply stores and coat the inside of the tank to prevent future corrosion problems. Follow the manufacturers directions.
Just use a little thin film of silicone dielectric grease on the seal rings and hoses. Remember the seal ring is a SEAL, no sealant needed! If it is old and hard replace it. Gaskets are the same, they are the seal, no sealant needed. The silicone grease is just to help it release and not stick the next time you pull it apart.
Originally Posted by Torque1st
A new tank is usually best if they can be purchased.
And there are repro tanks available, which appear to be good quality, at least the one I got from LMC was.
I *have* had more trouble with a leak at the fuel line connection at the top of new tank, though much less trouble with rust in my filter.
In my case, the fuel line connection may be more of my own doing -- I wanted stainless, which is notorious for being less malleable and more "leaky" than good old steel.
good luck
John
good luck
John
FordF350Baby
04-21-2020 09:16 PM
JMZ1970
05-15-2017 10:05 AM
RBerry9511
09-30-2014 09:45 AM
