Removal of the Vapor Cannister?
I was told by a local mechanic that you can remove one or both of the vapor cannisters on your truck to increase horsepower/milage? im not sure if he knows what he is talking about but if it can be done i will deff. do that so if anyone knows anything about that any info will help thanks by the way i have a 1991 f-250 460
on
I don't see how removing the canisters that filter the air that gets pushed out of the block by the pumping motion of the pistons would help horsepower or milage. You won't be removing a load from the motor by removing the filters, just poluting more.
And yes, the ECU can store codes without showing the CE light.
I need a new canister ... so ask him if he has one that was removed from a dual tank 90 inline 6. That canister captures the vapors from your tank(s) in it gets purged and brought into the combustion process ... if anything removal will cause a change in MPG ... not HP ... and that change will give you more MPG only if you pay for your fuel in pennies and nickles.
I have heard hooking it back up will help with MPG ... but that could be from the LMC catalog, mine had been "disconnecte" (broken off inlets) since I got the truck.
