msd distributor
Old Dec 24, 2006 | 08:35 PM
jwtimme's Avatar
jwtimme
msd distributor
I'm looking at buying an msd pro-billet distributor for my 390. I'm shure it comes with a small cap, and my jegs catalog say that the adapt-a-cap does not fit the 390 distributor My question is does msd make a bigger cap for the 390 distributor
Old Dec 25, 2006 | 04:25 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just one question? Are you running a built to the hilt 390? where your engine would benefit from a High dollar MSD?
If not...Just upgrade the points with a Pertronix set-up..and save yourself some money and headache..... JMO..
RJ
Old Dec 25, 2006 | 02:24 PM
strokerfe's Avatar
strokerfe
I don't think MSD makes a large cap for the FE, I believe MALLORY makes one, I believe it is there 9000 series or something like that. You can go on their website and check it out if you are interested.
But like RapidRuss said their is really no point in it unless you are spinning the thing up to 7500rpm constantly to prevent flex, or you just want the "wow" factor under your hood.
HAPPY HOLIDAYS ALL!!
Old Dec 25, 2006 | 03:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
caps
Originally Ford made two caps for the V8's.
B7A-12106-A standard...fits darn near everything from 1957 thru the end of the points era.
B7AZ-12106-A HiPo cap...Brown in color...rare to see or find one today. Same application as above. This rare cap was later replaced by D5AZ-12106-A.
Old Dec 26, 2006 | 07:54 PM
jwtimme's Avatar
jwtimme
answer, yes I have a built 390 and yes I turn it tighter than I should so I think I will benifit. I already run an msd 6al ignition and a 77 electronic dist. w/ vaccume advance which is not even hooked up because the motor will ping bad when hooked up. Which leaves me only the 12 degrees advance which is built into the dist. and what I put into it. The reason for going with an msd is to eliminate vaccume advance and to have better control over my advance curve and be able to tune the advance curve. I bought the bigger cap to fit the 77 dist and was wondering if msd mad the bigger cap too, which i do not think they do.
Old Dec 31, 2006 | 08:47 AM
Barry_R's Avatar
Barry_R
No big cap...
But the small cap seems to work OK on pretty swoopy engines. It is vented.
Old Jan 2, 2007 | 12:21 PM
jwtimme's Avatar
jwtimme
Just to let people that run msd dist. I did some checking and made a phone call and they do make a big cap to fit the FE. It is PN 8441.
Old Jan 4, 2007 | 08:54 AM
1966Tbird's Avatar
1966Tbird
i have a msd distributor for sale i'll take 220 for it it's a msd pro billet dissy in an unopened box (got 2 instead of 1) has mechanical advance not vacuum
i also have a stock distributor with pertronix, a summit racing cap, pertronix wires, flame thrower chrome coil i would be willing to sell all of that for 200
give me an email ksbsn88@aol.com
F-250 restorer
17
Jun 20, 2017 09:26 AM
secreto622
1978 - 1996 Big Bronco
Dec 5, 2016 03:42 PM
sand1
Sep 4, 2016 07:24 PM
351Cleveland C4
Feb 25, 2016 06:43 PM
Poes
Jun 6, 2015 08:22 AM
