55w fog light upgrade
A great upgrade is to go to the 9005 bulbs in your foglights. I did the homework on it almost two years ago and put the 9005s in both my '03 Cobra fogs and my '05 Excursion. Huge improvement. Very slight increase is power usage, but by no means dangerous or the like.
9005's are a direst-fit replacement, they go into the stock lamp-housings and hook right up to the stock harness.
Sileverstar 9005's are amazingly brighter, I have had 'em for two years and 35K miles, run them as daytime lights and did the 15minute mod so they stay on with my highbeams. Very happy.
Merry Christmas!
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Merry Christmas!
Quietman
www.roenation.com
I used http://hirheadlights.com/ these on my Suburban and they were certainly brighter than stock, but used the same or less current. I don't know if they have a size for our truck or not. EDIT They have the 9005, which would fit our fogs. These use same wattage, but generate less heat than stock. You have to trim them down with fingernail clipper. Easy.
think that' the steveracer mod.... cut the light green with black tracer in slot 13 and ground it - let me find the link b4 I tell u how to shutdwon your truck ...
http://www.ssdiv.com/fogfix.html
The thread:
https://www.ford-trucks.com/forums/5...dlights-2.html
Two pics of what I did:
<IMG SRC="http://www.martialartsacademy.org/ex%20mod%20harness.JPG">
<IMG SRC="http://www.martialartsacademy.org/ex%20mod%20ground.JPG">
Soooo easy, and after a dozen camping trips i can't imagine going without...
Quietman
www.roenation.com
Quietman
www.roenation.com
